Breeang's Avatar
Question Valeo alternator
I need some advice here. I just bought a new replacement Valeo alternator for my
'77 S. The outside diameter of the rear of the new unit does not fit inside the mounting ring on the fan housing,(Where the bolt holes are) and the bolts barely reach out of the holes-- WTF ?.
The fan housing is marked 901 106 101 5R .
Has anyone come across this problem before?
1957 KR 200 Messerschmitt Bubble Car 3 wheeler-my first rear engined air cooled German car,alas long gone!.
1977 911S 2.7 to spend money on
2006 Tundra for acting grownup
Old 12-13-2012, 06:49 PM
I recently replaced the alternator in my 1975 911S with the replacement Valeo (with voltage regulator) and it went smoothly. My fan housing has the same number as yours.
Did your old alternator have a spacer ring between the alt body and fan housing? If so, you won't need it with the new alternator.
Maybe it's just a matter of rotating the alternator because the bolt holes are not evenly spaced?
Old 12-13-2012, 07:09 PM
Breeang's Avatar
Angry
The bolt holes line up okay, and the Valeo slides in about 75% no problem then stops dead. There is a flange on the back of the Valeo that is the problem, it seems to be about 2mm larger in outside diameter than the inside diameter on the housing it should slide into. The housing is from a '74 though, as was the old alternator. (Now I'm thinking out loud), does anyone know if Porsche fiddled with the housing dimensions between '74 and '77?
Old 12-14-2012, 04:33 AM
Perhaps my experience will help. I ended having my alt rebuilt.
Alternator Question
Old 12-14-2012, 05:40 AM
kodioneill's Avatar
Some fan housings are more shallow than others. I've taken some to machine shops to remove the excess so the new alternator fits. Now I take the defective alternator to a local shop and have it rebuilt so I know there's no issue.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-14-2012, 05:44 AM
Mid 9, Upgrading Alternators, Regulator compatibility?
Looks like 1975 and up fan housings were machined deeper for larger alternators.
Old 12-14-2012, 05:55 AM
Breeang's Avatar
Yup that's what I was thinking (after the fact of course), thanks guys.
Old 12-14-2012, 06:44 AM
See post #12 for a chart showing the range of 911 alternator dimensions:
Vertex alternator housing
Old 12-14-2012, 03:53 PM
Senior Member
Jdub's Avatar
+1 on Driver X' comment - have your old unit rebuilt (hope you did not core it). Folks should take this advice to heart - you'd be surprised what a good local electrical shop can rebuild and these units can be pretty hardy. As a backup, or possible sale in our classifieds can yield decent profit after having it rebuilt.
'78 Targa in Minerva Blue
Old 12-14-2012, 09:11 PM
