Question Replacing windshield on 82 SC
My windshield took a rock today and will need to be replaced. However, I am wondering if the newer windsheild from an 86+ Carrera will fit. I would like to use the in-windshield antenna instead of the power antenna on the fender. Is this an easy replacement (i.e. plug and play)?
Old 08-16-2001, 09:13 AM
Post
I replaced my seal about a year ago. I do have the integrated antenna.
Not sure on the fitment, but you will need an antenna amplifier...
You might also need to drill a hole for the antenna wire. Not sure on that either.
I don't see why a later style windshield wouldn't fit though...
Good Luck!
Nick Hromyak
'85 Carrera 7 & 9 Fuchs
Havin' Fun in Sacramento
Old 08-16-2001, 10:41 AM
Senior Member
Superman's Avatar
Post
It is my understanding that the newer windshields physically fit the older cars. The glass installers I have worked with report that the later windshilds are more difficult to install because of the antenna. Don't know why though.
'83 SC
Old 08-16-2001, 12:08 PM
I was looking into the same thing. Everyone I spoke with said the windshield will fit. You also get to use the seal that eliminates the trim molding.
The down side is you are left with a hole in your fender and the windshield will cost you over twice as much. I also understand that it is necessary to drill a hole in the winshield frame to pass the antenna connection through. You will also need an antenna amplifier to receive a signal.
Paul
78SC Targa
Old 08-16-2001, 12:14 PM
Post
Actually, the windshield will be replaced by insurance. As far as the hole in the fender is concerned, for the time being, I would leave the antenna in but just disconnect it. Instead I would run the windshield antenna to the stereo. I have not heard about drilling the hole for the windshield antenna wire. Can someone shed more light on this. Also, more info about the antenna amp would be helpful. Thanks.
Old 08-17-2001, 09:56 AM
