Casis
On my 87 Carrera Targa the CASIS light works on some days and not on others. No pattern and no problems or symptoms. Just the light not working. Anyone have any thoughts? Thanks. Chuck...
Chuck 1987 911 Targa 1962 C182 "Dirt is permanent. You can move it around, but you can never destroy it." |
i don't remember one on mine. put your glasses on, and look closer.
I thought cassis was something you added to champaign to make a kir royale.
David Schultz 1973 911T 2.7 |
Pre Registered
Chuck,
I would suggest just disconnecting that goofy light altogether. Very simple to do. On the six spade connector on the bottom, center of the back of the tach, the CASIS/upshift light is controlled by the black wire/spade that connects to the upper left corner (Terminal 1) of the connector. Disconnect, tape off and you're done. Unless, of course, you enjoy the tach nagging you about fuel economy... Tim Last edited by tchanson; 06-24-2002 at 07:46 PM.. |
Thanks, Tim. Will do that. I don't see much use from the light, just another distraction.
You can also just remove the bulb and forget about it.
Yes the light can be very annoying. But the light will also tell you the optimum shift points during brisk acceleration. Dash mounted tach/shift lights are all the rage with kids these days. Porsche cleverly disguised their shift light as a fuel economy indicator. Even 007 doesn't have something like that in his BMW 750.
Lee's Toys, 1986 911 Coupe (139k miles) - Running strong, daily driver. Stock A/C, blows 35 F air when outside temp is about 90 F, in Seattle!!!!! 1987 911 Coupe with LSD (64k miles) - G50 a little more forgiving, garage queen. 1998 4Runner SR5 V6 4WD with TRD Supercharger - Supercharger gives the 4Runner a dual personality. With this great summer weather, 4Runner has become an garage queen too. |
