Which front strut version do I have?
I'm looking to do a suspension refresh - incuding new shocks. I've been reading that there are different strut version and I need to get the proper shock to match the version I have on the car (is that right?).
With that said, I have an 84 Carrera Coupe which I read somewhere it looks like up through mid-85 ish the cars had Boge struts. But then I read that green shocks indicate Bilsteins - and my shocks are green.
Any help? Also suggestions on a good shocks to use for replacement is welcomed. Car is a street car with some DE/autox events.
Thank you!
-Derek
'84 911 coupe
Old 01-02-2013, 03:22 PM
schumicat's Avatar
bilstein will have a roll pin at the bottom. others won't.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 01-02-2013, 03:27 PM
Cool thanks!
Any opinions on a standard bilstein insert vs. the HD version?
-Derek
'84 911 coupe
Old 01-02-2013, 03:44 PM
Standard ones ARE HD.
The other option are Sport inserts which are too stiff for stock-sized torsion bars.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-02-2013, 04:05 PM
