Senior Member
Welding SC Sway Bar Mounts
I have to replace a cracked rear sway bar mount.
I want to get a pro to do the welding, since it is a unibody and galvanized metal, but I am unsure how to get everything aligned once the old mount is ground off. I would like to do the prep work and perhaps even tack weld it before getting it permanently mounted, but I am afraid to lose all of my reference points by grinding off the old mount. Any advice or experiences from those who have done (or had done) this repair would be appreciated. Also, are the aftermarket mounts out there improved over the factory upgraded ones? How do the Weltmeister ones compare? Thanks, Olivier
Olivier Hecht 1982 911SC Last edited by ohecht; 12-16-2002 at 05:42 AM.. |
It's a very simple project. Leave the sway bar attached at the ends and use it to locate the new mounts. Yes, the new factory mount is improved. Don't know about the Weltmeisters.
Be sure to remove the undercoating AND the Zinc coating in the area you are welding. The undercoat is obvious. The zinc will contaminate and weaken the weld, not to mention liberating toxic gases during the welding process. Heavy metal posioning is cumulative.
Tony K '89 944T 944 SuperCup Champ 2004 & 2005 '85 Carrera - Sold [sob] TrackVision 944Cup The 999 Site |
Metal Guru
I like the Smart-Racing reinforced mounts. Don't know how they differ from the factory mounts, though.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
This is a well timed thread because i just ordered a set of revalved shocks, and Smart Racing rear ARB mounts with the stiffening kit that they make. I will post pics of the products here tomorrow.
Paul
My ignition is retarded. |
I'm getting ready to do this and other threads recommended Zinc Weld Thru primer, which is easily found at NAPA, et al. Am I missing something?
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Spiderman
The comments on welding on zinc are common knowledge, you should avoid breathing the fumes. Also will make for difficult decent welding. Just remove it all ! Not sure what the "primer" is supposed to do but I bet you still want to avoid trying to melt zinc into your steel and breathing it.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Spiderman
weld thru primer
I was curious, looks to be a primer paint that has no zinc or copper in it so if you have it painted on metal (with no zinc on it) you can weld right on it without poisoning yourself. Still have to remove the undercoat and zinc. You still do all the removal and paint this stuff on and then take your time positioning the mounts without the bare metal oxidizing in the between time till welding I guess.
Back to Olivier's original question-
The basic design flaw is that as the original sway bar mount, called a console by Porsche, would flex as the sway bar went through it's range of motion. Like the exercise of bending a paper clip back and forth repeatedly, the console will eventually fracture. I've owned 3 911's that have fractured their right rear console over time. In each case I've replaced the console with the factory updated part. But to prevent it from happening again on each car I've fit an additional piece of metal to triangulate the console. So when I picked up my current '86 I closely inspected the consoles and sure enough the right rear had about a 1/8" crack starting. So I welded the crack and added the triangulation and haven't had a problem since, including something like 30 track weekends with big Tarett sway bars. However, the triangulation isn't legal for Club Race stock class or Spec racing.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
The Dude abides...
By the way, you generally don't 'want' to breath in ANY metallic fumes zinc or otherwise...just sayin'.
WEVO is the way to go...$180 and you'll never worry about the mounts again.
Steve '03 Carrera 4S |
Undocumented User
I got the WEVOs, I had the same thing cracked right factory rear, upgraded and the difference in the support beef is healthy to say the least.
Rear Nounts Attache to Torsion Tube: ![]() Drop Links Attached to Swing Arm:
Northern Motorhead
Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
