SC Mutt
Ready to rumble
Hi all,
Thanks agai for all the support and insight. I have hooked up the msd and tach adapter. Put new heater hoses on. I also put a new alternator belt on and tightened Dow to 29 ft lbs. oil changed, new spark plugs. Cleaned sump screen and new gaskets and new oil supply lines where required. New air filter. Smog pump filter and per sprayed the spark plug openings with deep creep to help lubricate motor. I will disconnect the fuel pump relay when initially cranking to prime the motor. My question is this. I cannot manually crank or turn the motor. When I put my socket on the alternator fan housing the belt slips. I.e. it doesn't move the drive shaft pulley. I checked the belt tension and its tight. Maybe. 1/4" play half way down on each side max. I was just going to crank the car and then thought, if it doesn't move the drive shaft manually what makes me think it will turn if I crank it electronically. Anyone else come across this.? And I did have 3 spark plugs removed while trying to hand crank it to relieve pressure. Any help or insight so I can finally turn this baby over is appreciated. Thanks, Gary Proud owner of 1978 911 sc targa 3.0 |
Banned
Try turning from the lower pulley. If your compression is good, it is pretty difficult to turn the motor from the fan pulley.
SC Mutt
May seem like a stupid question, but how the heck do you get to it? The motor is in the car and it doesn't look like any type of socket with a breaker bar or 1/2 wratchet would fit. Please advice.
Thanks again. |
Banned
Open end wrench. I don't remember the size, maybe 19mm?
Try pushing in (right side) on the belt as you turn the alt.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
I'm probably the only one to have done this, but is the car in gear?
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
Banned
I have done this more than once.
SC Mutt
In neutral. Am going to fire it up tomorrow.
Will report back! Thanks Gary |
Irrationally exuberant
If the belt *doesn't* slip when you turn the alternator nut, the belt is too tight. To turn the motor over, you need to pinch the alternator belt with your fingers to make it grip enough.
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Senior Advisor
just put it in gear and roll the car, how much fluid did you squirt into each cylinder? you don't want to hydraulically lock the engine, bad news. Try to turn it over with the plugs out first
08 Cayenne Turbo |
