First picture with low and cool stance , but ****ty handling ![]() Second picture raised 1/2 inch, poly/bronze all round, HD shocks, 21f 27r torsions. alignment, corner balance, amazing handling ] ![]()
J Mac Current 0 Sold - 67 911T Coupe racecar, 87 911 Cabriolet, 85 911 Targa, 98 Boxster, 95 993 Coupe, 88 911 Cabriolet, 75 911 Carrera #144, modified |
J Mac, nice ride, black seems to be the color! My targa is black as well. when i rebuilt the front end i didn't check the height but indexed it to Eruopean standards, it came in at 25inches, while the back is 24 inches, need some adjustment there, what is your height to the fender lip? I didn't go with the poly bronze bushings, maybe need to tweak it again, and change the sway bars to your specs. It does however handle a hell of a lot better than before the rebuild. Now to rebuild the rear and replace cv boots....lord knows what i'll find back there..
Thanks Chris. Measuring from the floor through the exact center of the wheels to fender is 25 1/8 front and rear. The polybronze don't create any noise (when properly greased), but neither do they dampen noise like the rubber would. For me the pb provide a crisper handling car.
Air Cooled
Good additions to the thread! Good looking car J Mac.
Chris, I went with raised spindles so that I had full travel even when lowered, along with optimal steering/suspension geometry. My car isn't as low as it could be with raised spindles, but she may go lower some day. Remember to be careful when comparing fender heights...these cars have plenty of variance, so good tuners use lower chassis points to measure ride height, and not fenders (although that can get you in the ball park.)
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
Air Cooled
The caps are where the bumperettes were mounted, yes. Each bumperette is 7.5 lbs...so that's 15 lbs off the far end of the car.
Just getting started on my suspension, figured I'd post a "follow in Craig D's footprints" pic...
Air Cooled
Looking good Craig! Are you making the trips down to the new C&C location in Golden?
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
'78 SC Elephant Racing Suspension Rebuild
Please disregard my earlier question I had posted for several hours, I was able to answer my own question, thanks for a great thread.
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 Last edited by bugstrider; 08-20-2017 at 01:59 PM.. |
Air Cooled
I still marvel at how well my car handles washboard bumps on the throttle, and how on-rails it feels in mountain corners of Colorado. Amazing cars, these 911s. ![]()
I've been following this thread for quite a while and find it serendipitous that it happened to get partially revived today. I just dropped my '87 off at Elephant this morning to have a full suspension refresh (read: no garage space for DIY).
Can't wait!
~Brian 1987 911 Carrera |
Air Cooled
If I lived closer, I'd spend time visiting Chuck and taking a look at the goodies in his shop. Let us know what combo of parts you used and how it turns out!
Thanks, The down time has been killing me. I'm going full ER PB with 22/29 TB's. ![]() Carrera sway-bars and I am rebuilding the steering rack. I am driving my Banana arms over to ER on Tues/Wed for their resto service they provide, considering exchanging the sport bushings for the mono-balls. ![]() ![]() Although I didn't plan in going with the mono balls in the front. Will probably be picking up the QC spring plates and hardware kit as well. I'm doing as much as possible myself. Just for piece of mind, I changed out the fuel lines from front to back while at everything else. Did you leave your 19mm Trailing Arm nuts on the bolts or did you upsize to the 22's like the bolt head? Cheers Just curious, I re read your parts list and you went with 21/28's on the TBs. Chuck recommended 22/29's since I want a firm feel but no intent of tracking the car. Your thoughts on the 21/28 vs 22/29 combo. Sent from my iPhone using Tapatalk
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 Last edited by bugstrider; 08-22-2017 at 10:24 AM.. |
I've gone back through all the service records from the prior owner I have beginning in 1991, and other than re-welding a rear sway bar mount, the suspension has never been touched. 30 year old rubber will no doubt be the root of many of the minor annoyances and handling issues I'd been noticing (vibrations at speed, steering slop, general "vagueness", etc). The parts getting installed are: Stock ball joints Rubber control arm bushings (sport hardness) Strut top camber plate bushings (sport hardness) Quickchange strut brace F/R hollow adjustable sway bars F Von Street shock inserts R Bilstein Sport shock inserts Turbo tie rods Spring plate bushing (sport) Trailing arm bushings (sport) F 22mm hollow TB R 29mm hollow TB Plus, alignment, corner balancing and ride height adjustment. And now, I wait. ![]()
Check the rear wheel bearings.
On my '82 they're were supposed to be sealed, had broken in half exposing the ball bearings upon disassembly (like yours appear). Part of the race remains in the hub. Regardless you might consider it one of those "while I'm there" things. Easy & inexpensive repair (relatively) while banana arms are on the bench. |
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Air Cooled
![]() I re-installed the 19mm. Works just fine. Regarding the torsion bars, it depends on weight of the car. My car is 2480 lbs and the 21/28s work great. Cheers.
To Craig and the other guys who documented their suspension refreshes in this theead: How are the replacement components holding up? Are the Elephant rubber control arm bushes still as good as when you installed them? Same question for the polybronze? Thanks in advance, John in CT (82 Coupe I'll be doing the suspension on this coming winter..)
I installed all new sport rubber bushings as part of a suspension restoration two years ago. Over the winter I found the left rear lower spring plate mount had begun to crack.
When I disassembled everything to install the Elephant reinforcement plates I found the inner rubber bushing had split half way along the top. It may or may not have been from the mount failure. The cracked mount was minor. I ended up switching to the Rebel Racing rear spring plate mounts and bushings. There is no added harshness or noise from them. I wish I had put them on the front too. Amazing product. Close up of how minor the crack was. Not the cause of the bushing failure IMO. ![]() ![]() ![]() Sent from my iPhone using Tapatalk
Derrick Last edited by 1979-930; 07-08-2018 at 06:29 AM.. |
