-   -   First Engine Drop of 2013? (http://forums.pelicanparts.com/porsche-911-technical-forum/726565-first-engine-drop-2013-a.html)
boyt911sc 01-30-2013 05:40 AM
I'll have a test run.........
Originally Posted by NoYouRelax (Post 7239949)
Tony,
I would gladly let you try mine before you decide to buy one.
Bill
Bill,
I'll bring something with and come over your place to do a trial run this spring. Thanks.
Tony
NoYouRelax 02-03-2013 06:26 PM
Not happy with the flywheel seal installation....
I pressed the seal in and it was cocked about 70 mils top to bottom. Then I pressed it deeper than flush with the case, and it squared up. A thin layer of Curil T on the OD seemed to make seal installation sticky going.
Should I redo the flywheel seal???http://forums.pelicanparts.com/uploa...1359944778.jpg
NoYouRelax 02-03-2013 06:35 PM
flipped
http://forums.pelicanparts.com/uploa...1359945297.jpg
http://forums.pelicanparts.com/uploa...1359945340.jpg
NoYouRelax 03-25-2013 11:17 AM
And now for round 2...... Second drop of 2013!
I didn't quite like the way the flywheel seal went in and I should have gone with my instinct and put in a new seal in (while I was in there the first time).
Either way, I found nice green Brad Penn dripping out of that area of the flywheel seal. Worse case, I will become proficient at these drops.
I managed to drive the car for a fun 500 miles after the first drop, and I will still be ready Spring, if it ever gets here. Still snowing here this 53rd day of February.
Razzmmmm Frazzzmmmm!!!
86911tlcab 03-25-2013 12:12 PM
sorry to hear that...have put the rear main seal in on two different occasions and just tapped them in with a something flat...never tried the tool set up you were using...hope it all works out this time...
NoYouRelax 03-25-2013 12:44 PM
Flywheel seal dry or with sealant on OD?
Did you install your flywheel seals dry or with a sealant on the OD? I used a very thin coat of Curil T on the OD of the seal. I think the Curil T made the installation tight. I will research this more before the next installation.
zippy_gg 03-25-2013 02:57 PM
I installed mine dry but the engine is still on the stand and the car won't be ready for a few more months so I don't have a verdict on dry Vs. Curil-T...
Nothing I read mentioned a sealant of any sort. I hope I followed the right instructions! ;) Time will tell.
