Question on rear window heating elemnt wiring
Hi guys - hope everyone had a good weekend.
I found loose wires under my parcel shelf wiring, I am assuming from my DPO since they were kind of just jammed under there.
I found several brown (ground) wire tucked away back there as well as two other non-ground wires. One is red with a black band, and the other is red with white rings on it. Could someone confirm that I'm reading the wiring diagram correctly?
Is the red / black band is from the rear fuse box to the rear window heating switch?
Is the red / white ring from the rear window heating circuit?
Thanks!
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 03-25-2013, 06:38 AM
Pictures of wires as found;
911 w/ 3.2
Old 03-25-2013, 07:50 AM
This is from memory so it may not be 100%.
you have a two stage window defogger element. The red/black wire comes from the defogger relay in the engine compartment and connects to the lower prong on the left side of the widow. The red/white wire also comes from the relay and connects to the upper prong on the left side of the window. The brown ground wires pass to the right side of the window, under the installed seal, and connect to the upper and lower prongs on the right side.
Again, this is from memory and hopefully someone can confirm or correct this for a 74.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 03-25-2013, 08:13 AM
E Sully's Avatar
The wiring diagrams show a single stage heating element. On a 2 stage relay there would be a contact labeled 86a where the white/black is connected, and a red/black to the additional heating element in the window.
With the 2 stage, the first stage is activated by the black wire from the defrost switch to the relay, and the red/white from the relay to the element. The 2nd stage is activated by the white/black from the switch to the relay, and the red/black from the relay to the heating element. Brown wires being grounds.
Ed
1973.5 T
Old 03-25-2013, 08:57 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Defogger relay.
From my friend @ Hella:
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-25-2013, 10:01 AM
Thanks guys - very helpful.
So here is a basic question - where are these supposed to physically connect on the car?
911 w/ 3.2
Old 03-25-2013, 02:18 PM
schumicat's Avatar
there are male connectors for the defrost wires in the side of the rear glass hidden in the rubber seal. you may be able to see them if you look closely and gently pull the seal back from the inside. the seal has channels used to run the wires up to the connectors and you poke holes to run them to the connector. it is a pain to run the wires and easier to install the seal without running them (especially if you live in a warm area and don't use defroster), so that may be why they were left loose when the seal or window was replaced at some time in the past.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-25-2013, 02:39 PM
There you go - thanks.
L.J. - sorry it didn't click when you explained it the first time. Long day already at that point.
911 w/ 3.2
Old 03-25-2013, 02:52 PM
