Coram Deo
All,
I have a 1980 911SC that came to me at the beginning of October. When it arrived, it was almost undrivable, due partly to it sitting for four months in shipping lots and on a big boat. As time has gone on, I am sorting through what I have and beginning to understand it (with a great deal of assistance from this list). First stop was the mechanic, who checked fuel pressures, replaced the WUR, and pointed me to a replacement CDI box (bought on this list, thank you). The alternator went to pieces, and while the car was stationary, I checked for induction air leaks using the positive pressure method, and I didn't find any. Related- when I remove the oil filter cap, I get no change in idle, which is supposed to be a sign of air leaks. I also got the chain tensioner update done successfully). With the new alternator in yesterday, I mistakenly set the timing well advanced, and was very surprised to find performance scintillating rather than grudging. So today I looked at the distributor advance, with the help of SC Distributor Curves - Little Long With vac lines closed off, 5° at ~950 15° at 2000 18° at 3000, 4000, and 5000. which is within spec of my Bentley (21° +/- 3) but the advance curve doesn't seem quite right. In fact, it's not even a curve!. So I suspect I have distributor disassembly and cleaning in my future. Distributor service (Clean and lube) real easy without removing the pinion gear! But is 13 MPG what I should expect? I've got 5 tankfuls of Standard Oil's (S.O., or Esso here) best through my tank, and it hasn't gotten better. Ignition components (cap, rotor, plugs) are near new. Is the advance curve enough to account for this? Where do I look next?
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio Last edited by RDM; 01-05-2013 at 08:40 AM.. |
That sounds about right.
94 turbo 3.6 74 carrera RS race car 05 denali XL "We are here to laugh at the odds and live our lives so well that Death will tremble to take us." Charles Bukowski |
If you drive your 911 like I drive mine, that sounds close.
Dustin |
Coram Deo
Driving is mostly village to village, which means 30 MPH zones, 42 MPH zones, and 62MPH zones, with some traffic. So lots of accelerating/decelerating, but not extreme speed.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
For city-like driving, 13mpg sounds normal...
Dustin |
Caveman Hammer Mechanic
18deg total advance?
35 deg at 5000RPMs is what I set my car to. I regularly got 24MPG at "drive it like its stolen speeds" Experiment with a different advance number, Jerry Woods suggested 32 degrees as a starting point, dependent upon octane available/used. I tried as much as 38 degrees, but the engine was much happier at 32. It is called tuning, every engine is slightly different and will respond accordingly, but 18 degrees total advance is not enough. At 25 degrees my car felt like it was missing 2 cylinders.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 01-05-2013 at 09:22 AM.. |
SLR
Nop! that is not good mpg. I have a 1985 911 carrera in exalent condition so think it is a good guide line. I am now living in Germany and drove from Dorset UK to Nurenberg about 1130 km and I got around 8.7k per l, but the car was heavy and all though the roads are very good I was sitting on a speed of 90/130 mph and at one point 163 mph! (stupid) and a huge difference in full usage,
but normally about 25 to 28 mpg. |
That is a lot even when no freeway in the mix.
Perhaps only small distances only on a cold engine? Still high. My SC does not have that fuel consumption.
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses. |
For an 80SC, at city driving, and if you lay your foot into it like I always did, 13mpg is right. Not a good comparison to that of an 84-86 carrera because of totally different injection system.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
I drive my 79 SC back and forth 4 miles to work in 30-45 mph roads with traffic lights. A few runs out in the country at 50-60 each week. I average 19-20 mpg. Driving all-day highway cross country I got 23-26.
Your mileage sounds really low, I suspect something is definitely wrong.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
Your getting almost 1/2 what I am getting on a CIS 82 SC.
I've driven alot of crap to get here man! |
13 MPG is carb territory....
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Coram Deo
ROW '78 911 Targa
Hook up an exhaust analyzer and see what you are running for a CO output.
I'll bet it's fairly high in the 5 ppm range. Lean it out to 3.5 and your mileage should improve.
NO way, 13 MPG is what you should be getting. City driving more like 18-20.
+1timmy2, Something is wrong in your mix? Timing does not sound right. |
Ironman has been
I've had it both ways - 18-20 city and 13 city. It's all about the throttle. But that is a subjective thing - like Timmy2 I would look at CO output.
1983 911SC Coupe - For Sale 1980 911SC Targa RoW - SOLD 2003 BMW M3 - SOLD |
