After reading all of the posts above (thanks everyone) I'm wondering if the issue is not power, or speaker selection, but installation.
I'm using an enclosure sold by Pelican (Moch-1 underdash). Here's the link: Pelican Parts - Product Information: PEL-MOCH-2000S The enclosure does not completely seal around the edges, and the back of the speakers, the magnet, may actually be in contact with the structure of the car. Would this cause me to lose mid-range and overall volume, forcing me to push the volume to the point of distortion in order to hear the tunes over the open-roof road noise? Are there installation instructions or does anyone have any guidance to help me improve the job I've done? |
AutoBahned
I had one and sold it - put the speakers in the door. Best place to mount the tweeters is in the corner where the windshield, dash & A-piller all come together.
That may not solve your top off noise issue, but will be better than the mock-1 (no, I did not mis-spell it). |
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
Undocumented User
Not simply closer, but also line of sight. The higher the frequency the more directional it is, so pointing the speakers towards your ears especially the tweeters will give you better results and better 'staging' of the sound.
There is NO audiophile worth their salt that would go to the EXTREME sound level you are touting, certainly not, NEVER, in a 911. Sorry this previous statement is just WRONG. There is NO car venue would that would justify your extreme. Absent having a concert hall no TRUE, actual, audiophile would go to those EXTREMES. But good luck with your hearing once you reach your seventies, or even sixties. Oh, my '78 Targa has a Kenwood "head", a Kenwood multi-CD player under the passenger seat aong with a Kenwood 5 channel 250 watt Amp. 4 upgraded dual cone speakers (6.25" front, 6X9" rears) with integrated crossovers (polarized capacitors GONE!). Kenwood Amp. includes a DC-DC voltage up-converter, ~200 volts for PEAK drive to those speakers. NOT a RICER or teenager (72) so sub-woofer NOT required. Nice system if/when I'm going slow enough, say in a rresidentual area or city stop and go traffic. On the road "at speed", top on or off, system OFF. Oh, QUIETEST summer use only tires that are available for a 911, and a spray can (4) of undercoat discharged into each wheelwell. Last edited by wwest; 01-07-2013 at 10:29 AM.. |
Undocumented User
The most valid point in your post and the one thing I do hope he takes your advice on is the hearing loss. Last edited by McLaren-TAG; 01-07-2013 at 10:15 AM.. Reason: apparently I had difficulty spelling the word to. :) |
Banned
Op, in effect, is building a 1000 HP engine without addressing some very obvious ancillary issues, like the WRONG car to begin with. |
SPEED (wind noise)! Basically there is NO audio sound system that will be functional fidelity wise in a 911 "at speed". Well, maybe the 996 and beyond. But even my '01 C4 benefitted greatly from "quiet" summer use only tires and a spray can of undercoat into each wheelwell. Last edited by wwest; 01-07-2013 at 11:01 AM.. |
your front stage distorts for one of 3 reasons: 1. you are sending them too much power 2. you are sending them a clipped signal 3. your crossover point it not high enough for the speaker i currently run an active system consisting of a pair of 1" tweets, a pair of 6.5" midrange in the door and a pair of 8" subs in a rear seat delete i made. they are powered by an alpine pdx5 (roughly 120x4, 400x1) but i am by no means using all of that power. my system is more than adequate for open top driving on any road. OP, i would suggest moving the speakers into the door to start, but also adding some vibration control of some sort. that will dramatically increase the output of your front stage. see my audio build thread for detailed pics on how i treated my doors. i would also suggest crossing your front stage at 100 at a minimum, maybe even 120. let your sub handle the sub duties, that is it's job. low frequencies are omnidirectional, and in the small cabin of a 911 you should be fine without any time alignment. what are the specs on your subs and the enclosure? installing them with too much, or too little, airspace can make any sub sound like garbage.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
AutoBahned
another problem with the Mock-1 'enclosure' is that speakers should be rigidly mounted & that thing is flimsy & flexible
I am waiting for the ebay pic of the spray can of wheel well undercoat next to his SPAL fans... Welcome WWEST, I am glad to see you are the resident expert on this as well...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Yup I meant total power, the amount of power being talked about here just surprises me unless we're building a competition audio system here to blast away everyone in a parking lot, but especially if it's hard to hear. I was actually incorrect about my headunit too, it's 50x4 peak (how they advertise it of course), 22x4 continuous, or 14x4 RMS and I've found this to be more than adequate for my two 6x9's in back and 6.5's w/ tweeters in front.
