On Tour
3.2 Hose assembly..questions
Please tell me about this hose assembly part...
It's role with air, fuel, vacuum? If vacuum it looks very prone to leaks.. Parts catalog says there is a check valve in it....best to replace? Any thing else? Thank you, Mike
- 2018 Cayenne S 958.2 - 1988 Carrera 3.2 Coupe Marine Blue (SOLD) |
Vacuum manifold for power brake booster
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Yep, vacuum. That one looks pretty decent. Check it for leaks and verify that the check valve is working and re install.
The Dude abides...
How would one quickly check the break booster vacuum assembly for leaks?
Steve '03 Carrera 4S |
FWIW, I have struggled with understanding how this thing boosts the vacuum applied to the brake booster - something about a venturi affect of the small vacuum port drawing a higher volume of air from the low pressure area above the throttle.... seems like a kludge. I've never put a vacuum gauge on it to verify it works, but I'm assuming it does. Every other booster I've seen connects directly to the intake manifold. HTH, Chuck.H '89 TurboLookTarga, 344k miles |
On Tour
Thanks for everyones input..
I think I will just buy a new check valve and just replace the hose clamps to try and shore the unit up as the it all seems a bit "loose" Is it safe to assume vacuum leaks here only affect the booster and not how the engine performs? Mike
Any non metered air entering the intake will affect the operation of the engine.
On Tour
....Thank you
The Dude abides...
Never ceases to amaze, the quantity of knowledge on this forum!
The deterioration of the reducer hose to the right on the gold line, they are almost always cracked.
Bruce |
