safe's Avatar
Moving the shifter back?
I have been thinking about moving the entire shifter towards the driver. I have looked at the tunnel and I should be able to move it about 30mm (slightly more than an inch) without much problem, just drilling a few new holes and shorten the linkage rod 30mm.
30mm doesn't sound like much but I think the difference would be big.
A little more modifications and 2 inches shouldn't be a problem.
Oh, yes. The handbrake would need to be shortened also (feasible), since moving that would be more difficult.
I don't have the useless center console otherwise there would be more work.
Any thoughts about this?
Magnus
Old 01-08-2013, 01:38 AM
Bad LT
Uncle's Avatar
Do it and let me know!
I must have T-rex arms but the reach forward kind of annoys me even with a "tall" Wevo shifter.
Ex Porsche Cup car with some boost and stuff.
Old 01-08-2013, 03:33 AM
BoxsterGT's Avatar
Porsche Crest
Have you considered a Hargett shifter? They work fantastic. Lots of info posted on them here on Pelican.
Handbrake not shown in this example, but will still work by adding a handle extension.
Also a word of caution...........be careful when drilling into the tunnel, as the fuel lines are there and are subject to damage. Its a huge job replacing them.
Len
Old 01-08-2013, 04:10 AM
Senior Advisor
James Brown's Avatar
i was thinking about that one. seems too hard to move the stock one over. might think about a custom shifter lever
08 Cayenne Turbo
Old 01-08-2013, 04:28 AM
safe's Avatar
I bet they do, but $595 vs $0....
I like the way it raises the shifter from an ergonimic point of view, but I like the long floor mounted shifter of a proper Porsche.
Furthermore, I want better access to the handbrake. That is the next order of business. I would like to be able to engage the handbrake easily for quick 180 degree turns when I auto-x.
Magnus
Old 01-08-2013, 04:49 AM
tobluforu's Avatar
Do a search, there is a person that has done this, has pics of the install, etc..
It looks like a lot of work, but if you have the skills and time..
Old 01-08-2013, 05:16 AM
haycait911's Avatar
I modified my shift lever. very easy with a torch, vise, and a piece of pipe. a big bend toward the driver then back to vertical. falls easily to hand now and doesn't bang the passenger's leg. might be an easier approach.
Old 01-08-2013, 06:53 AM
you can also make the lever a bit longer with an extension. the amazing "long" shifter
206 637 4071
Old 01-08-2013, 07:29 AM
safe's Avatar
Yes, I remember that thread for a few reasons
Moving, bending, extending.... There are a few options, I'll have to mount my seat first to see what will best suit me.
Magnus
Old 01-08-2013, 07:48 AM
Porchcar guy's Avatar
I have a short shift kit and then bought a 3" extension last year using a MOMO knob and now the shifter falls almost straight down from the 380mm OMP wheel and there is no shoulder movement going into 1-3 or 5. I think the extension came from Sherwood on this site. Combined with ivangene's coupler and new shifter bearings, my shifting of the recalcitrant 915 is now almost like a real car :=) and it involved no cutting or moving AND it looks stock.
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 01-08-2013, 08:36 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
This was done on at least one of the 911Rs and if I recall correctly had a shorter, straighter lever arm.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 01-08-2013, 08:50 AM
gtc gtc is offline
abides.
gtc's Avatar
BTDT, You need an even taller knob...
http://shpws.me/lMRa
Graham
1984 Carrera Targa
Old 01-08-2013, 09:09 AM
I moved mine back about 7 inches along with the handbrake. The shift feel is better in that it no longer feels like stirring mud with a long stick, but it was a lot of work.
regards,
Phil
Old 01-08-2013, 10:03 AM
porsher
aston@ultrasw.c's Avatar
I did it, see this thread towards the end.
Raising / relocating 911 shifter
Works great no issues for me.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 01-08-2013, 10:38 AM
safe's Avatar
Wow, that's exactly how I intend to do it.
Magnus
Old 01-08-2013, 10:51 AM
AutoBahned
RWebb's Avatar
a cable shifter might be an interesting project
Old 01-08-2013, 11:15 AM
porsher
OK one small thing.
The shifter housing was raised by the thickness of the spacer but the receiver on the end of the shift rod remained at the original height.
Therefore the nylon bearing on the end of the shift lever was not fully engaged in the receiver.
Not having a lathe to turn the correct ID, I purchased a used receiver, cut off 1/4" and welded.
79 928 Race Car
Old 01-08-2013, 12:29 PM
Increasing the lever length accomplishes the same. 3" extensions:
Before and after
Sherwood
Old 01-08-2013, 05:28 PM
Reifle's Avatar
I have a 3 in. extension on my shifter... A fellow pelican made it for me!
'77 Porsche 911S
Old 01-08-2013, 06:34 PM
kjchristopher's Avatar
Where do you pick these up?
Old 01-09-2013, 07:41 PM
