Need Help identifying seals location
Guys,
Need help identifying these seals location. 1. ![]() 2. ![]() 3. ![]() 4. And if in the Door Sill location would I need any seal or rubber there to tap those holes?.
Go-Kart Mozart
Photos one and three are not showing up for me. Two is shown below as #30. Seal is screwed to body inside door opening and seals the door to body. Runs from top rear of door opening frame, forward and down to a point a few inches where the A-pillar stops. Four in my car is a rubber trim piece that is glued down listed as a threshold strip or rubber pad depending on where you look. 911.551.(619/620).00 for left and right. -J
pics are back
Go-Kart Mozart
Three is just the sister to two. Velvet door seals are left/right. One is not ringing a bell. Best guess is for windows. Is your car coupe, targa or cab? If there is a part number on the part type it into the Pelican Parts Search numbers only.
Go here and download the correct PET for your car. See if you can find a match. Porsche Original Parts Catalogue - Parts and Diagnostic Information - Porsche Service - Dr. Ing. h.c. F. Porsche AG By the way. Welcome aboard! -J |
tks J
1979 911 SC Coupe 2000 VW Passat 1.8T |
