Jtt84911's Avatar
Bilstein Frt Strut Replacement Issues & Questions
Hi Guys-
After reading many PP posts on front suspension upgrades.. started and started my winter project.. sway bar bushings, control arm bushings (ER -OEM rubber kit ordered through or host) ball joints and new strut cartridges.
Won't go through the all the time and effort required to get the ****** BJ nuts off.. because there many GREAT POSTS AND THREADS already on this (one came off after several minutes with the torch and big pipe wrench.. but the other one had to be cut off with Dremel cut off discs) Of course same deal with the treaded "pins" that fasten the BJ to strut. (one popped right out with punch.. but the other one required grinding off the non-threaded end with Dremel and then it banged out with a few wacks)
So... anyway after that.. I expected the strut removal would be easier/quicker - but off to bad start!! I could not get the roll pin out (SEE PHOTO 1) ... BUT I did not have the perfect sized punch (in the next few days will pick up the Sears 43167 roll pin punch set - that has ben mentioned in many posts- but I did not know about until tonight!
So here's my first question
I assume the pin locks the lower struct shaft via this groove?? (SEE PHOTO #2) I would have thought there was a hole in the shaft.. but the groove concept is waat was used on BJ so guess it makes sense?? OR did I get order the wrong catridge??
Did brakes last winter (new rotors/pads + 4 caliper rebuilds at Goldline and turbo tie-rods) and didn't see any sense in draining brakes disconnecting tie rods and removing wheel assbly... but the with BJ's + control arms off and top strut nut removed the only thing supporting wheel assbly is tie rods to steering rack .
So here's my second question
The wheel assbly is supported (SEE PHOTOS 3-4) but there's been alot of front to back movement... is it possible to damage the steering rack or tie rod???
JT
Old 01-13-2013, 10:11 PM
schumicat's Avatar
1. the roll pin doesn't go in a hole, it nestles in the skinny part of the shaft so it can't move up or down.
2. i'd check if the tie rod boot got ripped from being at that angle
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 01-14-2013, 05:28 AM
Recreational Mechanic
Nickshu's Avatar
Hate to say it but this job would be much easier if you were to detach the tie rod, brake caliper and associated pad wear sensor wires, remove the rotor, and get the whole assembly on the benchtop.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 01-14-2013, 06:18 AM
Jtt84911's Avatar
For anybody reading the posts....the Sears Roll Pin Puch Set worked GREAT!!
A MUST HAVE to get out roll pins in my opinion. Called 5 Sears Harware stores near my house...all sold out. Finally found a store 45 min away had 1 set left.
Couple wacks and stuck pin came right out and other strut pin took only like 5 minutes.
FYI -unlike standard punches there's a little nub on the end of the punch that fits into the center (ID)
Will take a pic and post.
New strut cartridges in.... BJ's and control arm bushings next!
JTT
Old 01-26-2013, 10:49 PM
Project Addicted
Good news and good work! Post some more pics and keep on working away at it. I spent a few hours in the garage yesterday and it cold out there. Stay warm and safe.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 01-27-2013, 05:33 AM
