epbrown's Avatar
Engine Lid - Part 2: revenge of the SC
Well, it's fitted and fine, went for a long drive with it and like it. But...
The turbo lettering the PO had on the tea-tray was rubber and glued on. The Carrera lettering on the "new" lid was rubber and glued on. So I ordered the 911SC lettering from Pelican and it's - metal, and apparently requires you to drill holes in the lid and screw it down with "speed nuts." I've decided I'd rather not use this, and I'm looking for alternatives. I'm thinking of creating a template using the real thing I got from Pelican and making my own rubber one and gluing it down, or even making a 911SC magnet (something very James Bond about being able to change the lettering on a whim - it's an SC, a turbo, a Carrera, an RS! I could make magnets of anything!)
Thoughts?
Emanuel
"Motorcycles... the cigarettes of transportation." Seth Myers
Old 06-28-2002, 10:19 AM
steve911's Avatar
Could you cut off the posts and glue it down like the others?
just my .02
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 06-28-2002, 10:28 AM
epbrown's Avatar
That's a thought - I'd probably need some sort of backing material between the two, like a rubber coating.
Emanuel
Old 06-28-2002, 10:35 AM
Administrator
Jack Olsen's Avatar
Yes. Grind off the posts and use trim adhesive tape.
Old 06-28-2002, 10:44 AM
Put it in a Xerox, then use the copy as a template to cut one from black adhesive. No one will try to steal it and scratch your lid at the same time. And you can take it off with minimal fuss.
GeorgeK
Old 06-28-2002, 01:01 PM
jwetering's Avatar
You are my new best friend - I've been trying to figure out how to get a 911SC script, only smaller, in decal form to put on my ducktail.
GREAT idea
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 06-28-2002, 03:41 PM
