Engine Lid - Part 2: revenge of the SC
Well, it's fitted and fine, went for a long drive with it and like it. But...
The turbo lettering the PO had on the tea-tray was rubber and glued on. The Carrera lettering on the "new" lid was rubber and glued on. So I ordered the 911SC lettering from Pelican and it's - metal, and apparently requires you to drill holes in the lid and screw it down with "speed nuts." I've decided I'd rather not use this, and I'm looking for alternatives. I'm thinking of creating a template using the real thing I got from Pelican and making my own rubber one and gluing it down, or even making a 911SC magnet (something very James Bond about being able to change the lettering on a whim - it's an SC, a turbo, a Carrera, an RS! I could make magnets of anything!) Thoughts? Emanuel
"Motorcycles... the cigarettes of transportation." Seth Myers |
Could you cut off the posts and glue it down like the others?
just my .02
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
That's a thought - I'd probably need some sort of backing material between the two, like a rubber coating.
Emanuel
Administrator
Yes. Grind off the posts and use trim adhesive tape.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Put it in a Xerox, then use the copy as a template to cut one from black adhesive. No one will try to steal it and scratch your lid at the same time. And you can take it off with minimal fuss.
GeorgeK |
GREAT idea ![]()
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
Author of "101 Projects"
I would cut the posts - it's really hard to get the tracing to look right. Just use double-sided tape to afix it to the car...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thread Tools | |
Rate This Thread | |
