Jp
Csi easy fix? 83 sc
Hello
Got a 83' sc engine starts up, revs up ok till warm
When approaches warm remains elevated around 2k for a longer time and goes back to 920 or so rpm
When fully warm, idle stays at 2k after throttle given
When i remove the oil filler cap and replace it idle goes back to 920 until throttle is given.
If i never give it throttle, rmp will stay at 920 no matter how warm it is
Car will shut off if i remove oil cap for over 2 sec.
Fuel pressures are around low normal
I understand there is a hundred possibilties and troubleshooting. I have been at this for a long time and are one step away from bringing it in to a ?mechanic?
John
Old 01-18-2013, 07:21 AM
Scott R's Avatar
I would disconnect the throttle link rod to the throttle body and try the test again. If that's ok then I would suspect the distributor is hanging up.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-18-2013, 08:09 AM
Josh D's Avatar
First thing I would check is to see if the metering plate is sticking. Remove air filter cover and air filter and push up on the metering plate arm to make sure it is moving freely. And like Scott said, make sure the distributer plunger is moving freely with the metering plate.
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 01-18-2013, 08:15 AM
Jp
Thanks. Will do
Old 01-18-2013, 08:53 AM
Try taking the vacuum line off of the decel valve and plugging the vacuum line and then trying the idle, that is what I had to do with my 83 when it actually ran.
Lorne M.
83 SC
Old 01-18-2013, 11:14 AM
Scott R's Avatar
Sorry I need to clarify, I was referring to the mechanical advance in the distributor. When they get dirty they hang after accel.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-18-2013, 11:23 AM
Josh D's Avatar
Yes! That can happen too!!
Old 01-18-2013, 12:34 PM
pete3799's Avatar
Post your fuel pressure numbers (system,cold, warm, and residual) and your WUR part number.
Do a vacuum leak test.
Without this info everyone is just going to be guessing.
Pete
79 911SC RoW
Old 01-18-2013, 12:53 PM
RETIRED
Joe Bob's Avatar
Fuel pressures and intake leaks are the main issues with CIS.
2012 ML350 3.0 Turbo Diesel
Old 01-18-2013, 06:24 PM
mca mca is offline
mca's Avatar
Did you try this?
It gets my vote. High probability of being the culprit and a very easy test to perform.
Lorne M.
Old 01-19-2013, 05:37 AM
Jp
Thanks Josh and Scott.
It seems like the lever in the air box is a bit stuck causing my issues. Improved by pulling slighty down on the lever in the air box. Will need to clean. Seems like this should fix my high idle.
Thanks again Pelicans.
As far as the Dizzy, Vaccum, air leaks yeah i got them too. But thats another story. I am still slap happy that idle has improved somewhat.
Old 01-19-2013, 06:26 AM
Scott R's Avatar
Pulling down on the arm actually adjusts the mixture a bit. Look up a thread by "souk" that explains why that happens.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-19-2013, 09:32 AM
