Jp
Csi easy fix? 83 sc
Hello
Got a 83' sc engine starts up, revs up ok till warm When approaches warm remains elevated around 2k for a longer time and goes back to 920 or so rpm When fully warm, idle stays at 2k after throttle given When i remove the oil filler cap and replace it idle goes back to 920 until throttle is given. If i never give it throttle, rmp will stay at 920 no matter how warm it is Car will shut off if i remove oil cap for over 2 sec. Fuel pressures are around low normal I understand there is a hundred possibilties and troubleshooting. I have been at this for a long time and are one step away from bringing it in to a ?mechanic? Thanks John |
I would disconnect the throttle link rod to the throttle body and try the test again. If that's ok then I would suspect the distributor is hanging up.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
First thing I would check is to see if the metering plate is sticking. Remove air filter cover and air filter and push up on the metering plate arm to make sure it is moving freely. And like Scott said, make sure the distributer plunger is moving freely with the metering plate.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
Jp
Thanks. Will do
Try taking the vacuum line off of the decel valve and plugging the vacuum line and then trying the idle, that is what I had to do with my 83 when it actually ran.
Lorne M.
83 SC |
Yes! That can happen too!!
Post your fuel pressure numbers (system,cold, warm, and residual) and your WUR part number.
Do a vacuum leak test. Without this info everyone is just going to be guessing.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
RETIRED
Fuel pressures and intake leaks are the main issues with CIS.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Did you try this?
It gets my vote. High probability of being the culprit and a very easy test to perform. Quote:
Jp
Thanks Josh and Scott.
It seems like the lever in the air box is a bit stuck causing my issues. Improved by pulling slighty down on the lever in the air box. Will need to clean. Seems like this should fix my high idle. Thanks again Pelicans. As far as the Dizzy, Vaccum, air leaks yeah i got them too. But thats another story. I am still slap happy that idle has improved somewhat. |
