OsoMoore's Avatar
The Culprit to My SC Starting Issues
This failing fuel pump is the culprit. The car always took a few cranks to start, and as the weather got colder the cranking got longer. After driving last night, I bundled my sleepy wife into the Porsche for a trip to the local club breakfast meet-up. And it wouldn't start. After 4 sessions of 10+ seconds cranking, we took the other car.
I went down the list of usual suspects, and discovered the fuel pump was at fault. Fortunately the PO had left an old used fuel pump relay (German-made!) in the smuggler's box. I switched the relays and it fired up on the first twitch of the starter. I swapped relays twice to be sure I had the correct solution.
So there you have it - if your SC is taking a lot of cranking or not starting at all, check that fuel pump relay!
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 01-19-2013, 11:17 AM
RETIRED
Joe Bob's Avatar
That or fuel pressure.....gauges are a good thing with CIS.
2012 ML350 3.0 Turbo Diesel
Old 01-19-2013, 11:29 AM
wwest's Avatar
Look closely at the fuel pump FUSE and fuse clamp/holder....
Is that relay even used when the starter motor is engaged?
Old 01-19-2013, 12:53 PM
Senior Advisor
James Brown's Avatar
the start (no pun intended) of a 30+ year old wire harness. expect similar "gremlins" to surface down the road. Good troubleshooting!!
08 Cayenne Turbo
Old 01-19-2013, 01:05 PM
