New Magnecor Wires & Distributor Cap. 1+1 <>2!
My car is a 1980 911sc and I order new Wires & a distributor cap that should fit my vehicle.
I ordered new Magnecor Spark Plug wires, PP #PEL-MAGN65-83, Magnecor #6594 they should go with my new Bosch Distributor Cap. PP #930-602-904-01-M14, Bosch #03008 unfortunately, they don't connect to each other! Any idea what my problem is? I can't be the first person with this issue. The cap looks similar to the existing cap I am replacing, but the spark plug wires have a different type of connector and do not connect to the cap. Black= Existing Bosch. Red = Magnecor
Give you $10 for the "old" ones. If intact. If intact, why replace?
Its just a car. |
Well, I tried really hard to separate the bosch wires from the cap, but the connectors were stronger than me. Two of the wires separated from their connectors at the connect to the distributor cap when I attempted to disconnect them. If you need a certain wire I am happy to send my old ones for only shipping costs, but two of them are ripped into pieces. |
Member 911 Anonymous
I love mine, just use the beru spark plug dust shield, the magnecor's will not last. lube and slip on :
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Just make sure and check with the company that you have the correct set for your car. A...
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
