Rescuer of old cars
Arne2's Avatar
Question [84 Carrera] Recommend good voltage regulator?
Any recommendations for a good, reliable voltage regulator for an 84 Carrera? Mine was replaced about 1 year ago after complete VR failure. Was replaced by a local alternator shop, no idea what brand VR they installed, but the lights are now starting to flicker a bit, and I figure I need to do it myself this time. So I'd love to hear if there is a particular brand or supplier that has been durable and reliable before forking over the cash this time.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 11-05-2012, 04:31 PM
djcdmv's Avatar
I did the Valeo VR about 2 1/2 years ago and haven't had a problem...
Dave
Black 1985 911 Carrera M491
Old 11-05-2012, 05:04 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Can you remove it to see what's in there?
'85 Carrera Targa
PCA/POC
Old 11-05-2012, 05:11 PM
Rescuer of old cars
Arne2's Avatar
I drive my car regularly, back and forth to work a couple of times per week, so I'd rather not tear it down until I have a replacement in hand. But I will report here what I find when I do replace it.
2018 718 Cayman 2.0
Old 11-05-2012, 07:28 PM
DRACO A5OG's Avatar
Please do update us, I need to replace mine soon. :-(
Just replaced VR in the 190e, fixed a boat load of issues :-)
'85 Carrera Targa
PCA/POC
Old 11-05-2012, 07:51 PM
Rescuer of old cars
Arne2's Avatar
Well, if there are no other experiences, I guess I'll go ahead with the Valeo from our host. Will post when I find out what the failing one in the car is.
2018 718 Cayman 2.0
Old 11-06-2012, 08:18 AM
Here is my guess at my voltage regulators fault. This is all speculation none of it was verified.
The charging system failed due to the brushes wearing and making intermittent opens and the voltage spiked. The slip rings also had 1/16th of an inch grooves worn in them.
Replaced the regulator which comes with new brushes and worked fine for about two years when the headlights started to flash again.
Decided to replace it again and when I took it apart discovered I had trapped a strand of the fiberglass wire shield under the screw. This either caused the brushes to wear at a funny angle or the regulator to burn up from poor thermal conduction.
Have been trouble free for 5(?) years.
Rick
88 Cab
Old 11-06-2012, 09:28 AM
Rescuer of old cars
Arne2's Avatar
Well, tonight I checked with my digital voltmeter, and I'm baffled. The meter showed an average of 14.5, never below 14.3, the highest bounce was 14.8. Now I realize that the refresh rate on the meter might not catch all the movement, but you'd think that if it was regularly spiking higher than 15.0, I'd have seen a few indications on the meter.
Any thoughts on other causes for all the lights to flicker?
2018 718 Cayman 2.0
Old 11-06-2012, 05:46 PM
AutoBahned
RWebb's Avatar
are they on relays?
Old 11-06-2012, 06:17 PM
Rescuer of old cars
Arne2's Avatar
Yes Randy, they are on relays. But I should clarify - the flicker is not just the headlights. It's the parking lights, the instrument lights, switch illumination, etc. Not just the headlights.
2018 718 Cayman 2.0
Old 11-06-2012, 06:28 PM
AutoBahned
RWebb's Avatar
maybe use an analog voltmeter to check - you tested under the same conditions as the when the flickering occurs?
next, I'd remove each ground and clean in a strong acetic acid mixture - I usually leave it overnight
I use an acetic acid saturated Q-tip or piece of paper towel held on the grounding point with tape - you can put plastic wrap over the area too & seal the edges
then hose it off with electrical contact cleaner and use dielectric grease when reassembling
was the car ever back East? West coast cars usually don't have ground problems to the extent that rust belt cars do
Old 11-06-2012, 08:48 PM
Rescuer of old cars
Arne2's Avatar
Yup. Watched it flicker while looking at the meter.
Was sold in NC, but moved to Seattle within 2 years. Here in the PNW ever since.
2018 718 Cayman 2.0
Old 11-06-2012, 09:02 PM
ROW '78 911 Targa
timmy2's Avatar
As all the lights are flickering I would tend to the fuse and connection feeding power to the light switch as well as the grounds.
Loose wire or connection at fuse terminal if you are lucky. Failing contacts inside light switch if not so lucky.
My new VR solved the flickering problem. Mine is external though, so a lot simpler to replace.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-06-2012, 09:36 PM
To respond to the original question, I would recommend a solid state VR such as
Zim's Autotechnik Voltage Regulator, 911 75-81
sounds like you have other issues though.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 11-06-2012, 09:54 PM
ROW '78 911 Targa
timmy2's Avatar
Too bad that won't work in his '84...
Dennis
Old 11-06-2012, 10:38 PM
Rescuer of old cars
Arne2's Avatar
Multiple fuses would have to be involved, and lights that are not fed through the light switch, too. For example, the flickering is visible in the trunk light as well, even with the headlights off. I'll have to do some more in depth troubleshooting this weekend.
2018 718 Cayman 2.0
Old 11-06-2012, 11:06 PM
Rescuer of old cars
Arne2's Avatar
Finally got around to this today. Was going to replace it yesterday, but the garage was too cold to work in so I bought and installed a garage heater instead.
Now with heat in the garage, I installed the new Valeo regulator I ordered from our host. The one that came out was labeled as a HüCO, made in Germany. (The Valeo was made in France.)
Seems to be all good. The flickering is completely gone. While the digital voltmeter was bouncing between 14.3-14.8 before, now it is rock steady at 14.2. Even better, I'd swear the lights are actually brighter now. The turn signals now flash at a consistent rate while waiting at a light, and the idle may actually be a touch more steady.
In any case, the Valeo seems to be a better choice than a 14 month old HüCO.
2018 718 Cayman 2.0
Old 01-20-2013, 04:10 PM
DRACO A5OG's Avatar
Yeap, just had mine re-built and not a very steady voltage, I don't know it may be but car seems quieter too
'85 Carrera Targa
PCA/POC
Old 01-20-2013, 06:54 PM
