French Import
Sanity Check on Initial Spring Plate Angle
With the engine out I refreshed all rear suspension bushings and wheel bearings.
Re-installing the spring plates I used Will Ferch's angle calculator 911 Spring Plate Angle Calculator, and my input was 25 mm for the TB, Euro ride height, and a weight of 3417lbs based on the VIN plate since I have no way to weight the car at this stage. ![]() The calculated angle is 36°- 37°, and the car angle was measured at 0° so I set the spring plates at 36°- 37°. I wanted to check with those with experience as it looks like the angle is pretty steep, but then again the trailing arm and shock are not attached ![]() ![]() Does this seem correct? I'd like to make sure before I reinstall the spring plate covers and tighten everything up. Any advice will be appreciated.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
I think you're going to be sitting pretty high using the GVWR
2600-2700# would be closer i think.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
This is a photo showing the spring plate angle on my 87 930.
I have to just raise the spring plate slightly with a jack to get the cover plates on. Basically, the bottom bolt on the cover plate is slightly covered with edge of the spring plate when you apply upward (hand pressure) on it. ![]()
Thank you, HFR_Racer '87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups. |
disband
that does seem pretty steep. ive always set up with stiffer bars, so less sag after loaded.. #3400 does seem a bit heavy, but im not aware of any actual weight numbers... you say its an 86, so thats not a g50 car? your photo angle may be playing tricks too?
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
disband
and oh yeah,, get some blocks under the trailing arm so it's not makin the brake lines get all hurt.
French Import
French Import
![]() Alas I cannot compare my situation (or pictures) with yours since the trailing arms and not connected to the spring plates yet. I am at the initial stage with installing the plates and I wanted my starting point to be in the ballpark before everything gets re-installed. Did I mention that is a very nice height on your car? ![]() Edited: I see what you mean not being able to install the bottom bolt without raising the spring plate
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate Last edited by zippy_gg; 01-20-2013 at 02:47 PM.. |
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
non-whiner
That bottom bolt is actually the spring plate stop and is designed to keep the plate from dropping all the way and stressing the brake lines when the wheels are in the air. The lowest you should go is described above (just requires a slight lift with the jack to get the stop bolt installed).
Zippy, I think your car will have a 4x4 posture with that setting, particularly if you installed larger than stock TBs.
"Too much is just enough." |
helpful hint - there's an AP for that - I found several smart phone free inclinometer aps that you can set zero on the door sill and then rest on the arm for quite accurate angle measuring
your GVW is way high..as stated - most likely closer to 2800#
Ed M 86' Coupe |
Weight is probably 2700 lbs range. I get an angle of 31-32.
Ed 1973.5 T |
The spec weight for your car is 2640lbs. The weight you are using is for fully loaded- passengers, gas ,luggage(what luggage?) etc. My 69 has a spec angle of 36 degrees. But it has a smaller TB than your car but it is also lighter by 400 lbs.
69 911 2.3Ez 85 928S |
French Import
Thank everyone for the replies. So much good info from people's experience here!
![]() I guess I mistakenly used the GVWR instead of the actual car weight. The calculator now shows 30-31 degrees for a 2640lb car. I am keeping the 25mm TB for the time being as they are in good shape and the car will be used for street and canyon driving, no DE or track days. I guess I better go to the garage and "fix" the spring plate angle!
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate Last edited by zippy_gg; 01-21-2013 at 11:39 AM.. |
French Import
The cinder blocks scare me though... Teen lifts car off trapped grandpa | HLNtv.com
