Senior Member
Post Oxygen Sensor wiring harness
Has anyone ever spliced in a new connector that goes from the car side of the wiring harness to the Oxygen sensor?
Seems that mine is broken now (assume was pulled too hard to try to get it to fit on the new SSI exhaust) and now I need to splice a new one on. I have gotten one off of a wrecked cars harness and know that its a two part wire, with a shielded outer and normal inner core.
Just how much fun is this going to be? Its not real easy to get to in the first place and will have to be soldered on to keep the resistance close to being correct. My dealer wants an hour labor to do it, so I thought I might give it a try this weekend...
Ideas? Anyone ever done this?
TIA,
Joe
Old 08-18-2001, 01:27 PM
carnut169's Avatar
Post
The O2 sensor comes with that wire (and the rubber "stopper")- just get a new one and plug it in.
87 Carrera Cabriolet
Old 08-18-2001, 03:21 PM
Senior Member
Post
Carnut,
I am talking about the wiring that comes out of the car that plugs into the harness on the Oxy sensor.
The plug coming FROM the body harness is the one that is bad... can buy that one, its only $5-600 bux and the rest of the motor compartment wiring harness... now you see why I am wanting to splice a new plug onto the lead!
Joe
Old 08-18-2001, 04:02 PM
Toxic
derkpitt's Avatar
Post
It is possible to splice into the harness.
But it's going to be difficult in the engine compartment. You'll need a special splice, [aircraft type], for shielded wire.
Derk Pitt
88 Carrera Coupe
Old 08-19-2001, 05:48 PM
Senior Member
Post
Derk,
Thanks... hope that someone had done it and could shed some light on what its like... of course the wire is back in the corner and not easy at all to get to!
Thx,
Joe
Old 08-19-2001, 06:54 PM
