Excellent, glad to be a beta tester if you want to see how it works on an 82.
Thanks for the bump.
yep, works on an '82. Right now looking for a few local volunteers for test fit to make sure that our sample size is greater than 1 before going to production. Are you in metro detroit?
--toddc todd@helioncomposites.com www.helioncomposites.com |
abides.
Looks great.
Will these use the stock side seals?
Graham 1984 Carrera Targa |
Thank you Graham,
the tops will be manufactured in such a way as to accept factory seals, guide pins and j-hook latches, we're dedicated to providing a turn-key factory type product.
How are the j-hook latches coming?
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
abides.
Very cool. Seems like this is what the factory should have done.
Here is where we are at.....
J- Hook Prototype is finished and ready for test fit/installation. You can see the latches in the pics. Keep in mind when viewing the pics, this is not the final product rather the prove out for fitment. That said, we're really close. ![]() ![]()
toddc, your hard top looks excellent. Hope it will fit really good. Just one question: What about the center 3rd guide pin on the rear section of the hard top? Should there not be at least a thread so it can be installed as an option?
I considered that option during the design of the J-hook frame and quite frankly I dismissed the need for a center rear pin based on the real world testing that was done on nineball's car with our original hard top. The carbon tops are so stiff that there is no need of a center support in the rear. The original carbon top has demonstrated it's ability to resist deformation at track speeds exceeding 100mph and I have no reason to think the J-hook version will not perform the same way. Regards,
Watching this whole project come together has been a real treat...and I don't even own a Targa!! BUT, knowing that a replacement for an old, leaky top may be available, I'd consider one now.
Kevin 1999 911 Carrera [996]-Vesuvius Grey Metallic |
Good thought. At this point, adding in the third pin is not really an option without considerable rework of the frame. Keep in mind, the factory only did this for a short period of time on the folding tops for the early targas. They never did it on their own fiberglass hard tops that were available for the '75 model. I suspect they also deemed the extra support unnecessary.
We're comparing apples to oranges. My carbon hardtop is a clone of the factory hardtop that was offered as an option in '75 that has been modified to allow the use of factory J-Hook latches that were used in all variations of the folding top from 74-86. The beauty of this hardtop is that allows someone to install it as they would their original folding top with no modification required and the added benefit that items like latches and guide pins are serviceable without the destruction of the top which is something that is not possible with a stock folding top. I truly hope this helps clear up that we are not making a comparison between vinyl tops and hard tops. Regards,
The tops look great! Thank you for all of your hard work on this.
Are you planning to sell them ready to install on the car, or will the buyer have to source latches? Any idea on pricing yet? |
Thanks Scott, I'm going to offer both a complete top and a bare top. Idea being that a buyer may have his/her own hardware left over from another top and want to use it and save some dough. Or perhaps want a complete top allowing use of the hard top while preserving their folding top. Either way, OEM latches and guide pins are available from our host and others and we can provide as part of a package or end user can source themselves. Right now pricing is being dialed in and not confirmed but should be right around the 2k mark for a complete top and less for a bare top.
--toddc todd@helioncomposites.com www.helioncomposites.com Last edited by toddc; 06-27-2014 at 07:44 AM.. Reason: grammer |
I can test it on a 1978 if you like
Thanks for the quick response. Will the fiberglass tops be primed and ready to paint? What sort or pricing difference are you looking at between carbon fiber and fiberglass?
Hi Scott,
fiberglass will certainly be available and they will be delivered in primer ready for paint.
