80 sc brakes
With a lot of help from this forum I have kept my car on the road. Need some more help. I have had to fill my brake master cylinder a lot lately. A couple of times it was basically empty. I have tried to find the leak with no luck.. Right now it is on four jack stands in the garage with the wheels off. I can find no fluid dripping anywhere. Any suggestions would be appreciated. Thanks
Have a look at your master cylinder.
JR |
80sc brakes
Is there an easy way to check brake booster filling with fluid or do I have to take the master cyl. and brake booster out. Thanks.
You can just remove the master cylinder and then dip into the booster with your finger, a straw or length of cloth to see if it is wet inside. This would indicate leakage at the rear seal of the master cylinder and the vacuum in the booster pulls the fluid past the seal. After a while, if you continue to fill the reservoir and this is in fact where the fluid is going, the fluid can limit the displacement and hence amount of braking you can achieve.
RETIRED
After it goes into the canister....where does it go?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Senior Advisor
there are couplings and tees under the car, trace the brake lines to all 4 wheels. got to be somewhere
08 Cayenne Turbo |
Senior Member
Have you had a close inspection of the driver footwell done? Checked for leaking fluid behind the pedal panel, saturating the pedal rack and environs?
'78 Targa in Minerva Blue |
