DP Motorsport Lightweight 911
I wasn't sure if this has been posted yet. I've seen some pics of this car coming together but I wasn't aware it was finished.
From www.http://germancarscene.com
Originally Posted by germancarscene.com
Known for producing some of the most incredible Porsche vehicles for almost forty years, Overath-based dp motorsport has built this work of art to demonstrate its latest featherweight products.
Starting with a 1973 911 base, dp stripped it back to an absolutely bare bodyshell before fitting the dp11 RS 2011 body kit. Constructed from carbon fibre, the kit consists of a replacement front and rear bumper, hood, fenders, fender flares, rear spoiler – and even the roof panel. Not stopping there, dp also fitted Plexiglas windows, lightweight lamp lenses and tail lamp holders.
Inside, the 911 is equally impressive, with the cabin featuring a carbon dashboard section, sill trims and dp 935 bucket seats finished in Alcantara and leather, along with an extensive, welded-in roll cage. Under the hood there’s a 70 litre Clubsport tank and strut brace.
In the rear sits a 228 kW (310 hp) 3.6 L boxer engine, which is fed by a pair of 50 mm PMO carburettors and mated to a G-50 transmission with a limited slip differential. Chassis upgrades include dp coilovers, adjustable stabilizers, and a 964 braking system, while those iconic Fuchs wheels are sized 9 and 13 x 15-inches, and wrapped in 225/50 and 345/35 rubber.
The result of dp’s carbon diet means that this 911 now tips the scales at 870 kg. Impressive when you realise that a standard car weighs between 1,080 to 1,335 kg – depending on the model.
1987 GP White 930
1977 Ford Bronco
Old 11-14-2011, 04:20 PM
Wood
Old 11-14-2011, 04:34 PM
ZAMIRZ's Avatar
It's been done for a while and there was another post about it when it debuted at Techno Classica Essen. But these are new pics, so worthy of a repost.
Amir
'83 911SC
Old 11-14-2011, 04:36 PM
bloody sexy.....
63 356 2.1 Rally Coupe
75 911M 2.7 MFI
86 Sports Purpose Carrera "O4"
19 991.2 S
25 992.1 GT3RS
plumb4u2's Avatar
wow what a beautiful car
Justin
84 Carrera Targa
98 F-150 4x4
Old 11-14-2011, 04:37 PM
Max Sluiter
Flieger's Avatar
I want that rear window.
Old 11-14-2011, 04:58 PM
Vintage Motorsport
RichardNew's Avatar
So these folks are driving around on the street with a full cage. Ok.
Richard Newton
Newton's Law
Old 11-14-2011, 05:27 PM
Max Sluiter
Flieger's Avatar
Hey, I do it. Not saying it is correct but I do it. Mine is not as stout as that. Just a bolt-in.
Old 11-14-2011, 05:28 PM
Max Sluiter
Flieger's Avatar
That one looks like it tucks up to the A pillars much tighter.
Old 11-14-2011, 05:29 PM
(man/dude)
Jonny042's Avatar
Richard Newton
Newton's Law
Is it a problem if you're properly strapped in?
Old 11-14-2011, 05:39 PM
draab29's Avatar
Clean
Dave
1984 911 M491
1986 911 Hotrod
Old 11-14-2011, 05:51 PM
That car has the perfect stance
Old 11-14-2011, 06:46 PM
oh snap's Avatar
Gorgeous. I love the Zuffenhaus Fuchs but when it comes down to it nothing looks better on a 911 than wide 15s
1985 Iris Blue M491 911 Coupe
Old 11-14-2011, 07:12 PM
Enthusiast
jrolstin's Avatar
The problem is the risk it poses to other drivers. If you were to get in an accident with another vehicle you would go right through it and probably kill the people in it. However your point still stands that you would be pretty safe!
Jonathon
1982 911 SC
www.avrmotorsports.com
Old 11-14-2011, 11:51 PM
Old 11-15-2011, 12:25 AM
hawaiipcar's Avatar
Send a message via Yahoo to hawaiipcar
That car rocks...
HAWAIIPCAR
75 911 S
Old 11-15-2011, 02:28 AM
a.k.a. G-man
Geronimo '74's Avatar
OK, I'll take the Cf lollypops...
Old 11-15-2011, 02:38 AM
You being serious? Majority of cages don't even alter the caged cars crumple zones...how do you suppose a caged car becomes a torpedo? Even if it were such that the caged car sacrificed all of its crumple-ability, the only person you would be putting at significantly higher risk would be yourself due to the higher g loads.
Old 11-15-2011, 03:47 AM
300hp 1800lbs is the goal
pksystems's Avatar
I don't think the cage will put anyone else in danger. A 2000lb caged car is still going to loose to a 4 tonne SUV. It should hold up better tho. It's the cage being closer to your head that is the risk. I'm adding a cage to my '66 for some protection from all these text-messaging tanks on the road.
Great pics BTW.
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 11-15-2011, 04:18 AM
Slippery Slopenose Victim
SXSMAN's Avatar
OK........hand me the hammer , broom and dust bin , also grab the shop vac.......
Any chance of going back on topic ?
sxsman@hotmail.com Have guns , will travel
Mr. Potato-head , 1974 911 Slant/turbo look 2.7
1963 Cooper S ex-C sedan , 1974 Vespa Rally , 1974 TVR 2500M (sold) ( Musta had massive head trauma in 74 , ya think ? )
Old 11-15-2011, 04:37 AM
