Mr E
So what percentage of SCs get broken headstuds
Serious question -lots of examples on here and its a common problem. But is it that all the owners with the problem post on here.
Can anyone estimate the percentage of cars to which it happens? |
non-whiner
There are three kinds of SCs. Those that have broken head studs, those that will have broken head studs, and those whose smart owners replaced the head studs.
sudo apt-get purge 930
Isn't the issue more common with the 2.7 rather than the 3.0?
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
110%
Checked out
18.4%
Even the newest SC is now 30 years old. What MREID said is dead solid perfect.
'17 Cayenne |
Reiver
except for a few....30 years old, original studs all in place and recently retorqued at 227 k miles.
I do agree that they will not last ad infinitum but I'll let you know in another 50k or so. |
probably tempting fate here but i have 117k on my 83 and all are original, re-torqued at about 110k.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Reiver
That's pulled studs on the mag 2.7...as in pulled out of the casing. The dilivar studs on some 3.0's break...usually in cars that have been in wet climates and driven on short trips (not fully warm) then garage queened allowing for corrosion to set in on the exhaust studs. What I've been told anyway by a few local shop owners as to the breakage.
Presence of Dilavar head studs........
Good to hear that some SC engines have lasted this long with the original head studs (Dilavar). Incidentally, some new owners never realize that they have already steel exhaust cylinder head studs in place. One way to determine the type of cylinder head studs you have is do a magnet test. Dilavar studs are non-magnetic. I've seen SC engines that were supposed to be 'untouched' yet had steel exhaust head studs already. So you be the judge.
Tony |
Recreational Mechanic
What I don't know is whether something changed on the early Carreras w/r to head studs. Is it just that SC's are older and the problem hasn't hit the Carrera's yet?
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Fleabit peanut monkey
Exhaust studs do not shear - they twist off. Dilavar studs get corrosion pits in them and heat cycling causes them to shear across the bolt diameter.
1981 911SC Targa |
Reiver
[QUOTE=boyt911sc;7246625. Incidentally, some new owners never realize that they have already steel exhaust cylinder head studs in place. One way to determine the type of cylinder head studs you have is do a magnet test. Dilavar studs are non-magnetic. I've seen SC engines that were supposed to be 'untouched' yet had steel exhaust head studs already. So you be the judge.
Tony[/QUOTE] If I remember correctly SCs only had 1/2 dilivar studs(can,t remember if upper or lowers. Turbos were all dilivar
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
RETIRED
Have had 3 seperate 3.0s.....one snapped two lower studs. So in my case, 33.3%.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
My 83 sc had 4 broken at 87K miles!
It's just something you have to deal with, and I would recomend that you think about possibly replacing the lowers every time the motor is pulled out if it has been more than 80K miles. |
Reiver
BTW, when I finally drop the eng it'll get a full rebuild but my leakdown tells me that might be awhile if everything else holds tight. |
I had mine done after returning from Desert Storm. The car sat idle for ~11 mos and did not take too kindly to running after I returned. So, in 1992 I did head studs at ~74K. The car's an '83 and I'd used it as a daily driver (excepting deployments) until then. I currently have 126K on it.
Don Newton “People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.” "I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams |
Weseeeee911
At 140K I found 2 broken head studs. Replaced all of them during a complete rebuild.
Al 80SC 95-present |
