Use Anti-Sieze
Hello,
After re-doing my front wheel bearings, I'm getting set to put everything back together (rebuilt calipers, new rotors, etc.). Should I use anti-seize on the rotor nuts/bolts that hold it to the hub and/or the two caliper bolts? When I removed them, it looked like there was something on the bolts (I presume to keep them from rusting into a metal lump that can't be undone). Thanks. Lawrence Last edited by Swoboda; 01-31-2013 at 11:53 AM.. |
I do...on the wheel lugs also...then torque properly..
I never do, and mine have been fine.
I am not saying I am right, just offering another opinion.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Spiderman
use it
I use it "carefully" on most everything that gets worked on periodically. Can't think off the top where I wouldn't use it if its outside exposed to water. Careful around the brakes.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
I would clean them with a wire brush and use a light thread locking compound.
Recreational User
I use anti-seize on every fastener that has a chance of galling or rusting in place.
I might be wrong, but I do this too.
Fat butt 911, 1987 |
The Wurth copper based anti-seize available from Pelican is superb - wouldn't be without it on any job.
Racer
Well, anti-seize shouldn't be used unless it is taken into account when tightening fasteners. If anti-seize is used, fasteners stretch more for a given torque.
Bolt Torque when using Anti-seize Scott |
You are not wrong at all. I think we each do things our own way. I do wire brush my bolts so they are nice and clean.
the bolt and the strut are completely different metals with no chance of galling
I dont use anitseize on these clean them - and that's it there is one product I put on most bolts that I do not use "anything" on - I put Krytox on them...and I mean a tiny damn amount - this stuff impregnates the steel and makes them work much better - I started using krytox about 15 years ago and have found it to be the best grease ever do some reading, you'll be quite impressed with the numbers also an amazing o'ring/seal lubricator Krytox® Lubricants - By DuPont
Ed M 86' Coupe |
If it rust, yeah do that. If it's very dirty with grease/oil/dirt, I put a bunch into a box, pour some paint thiner and shake them up.
Ed, what do you use to clean up Krytox? I read that stuff is pretty nasty and you really should wear gloves and a respirator, no?
Racer
rusnak,
There are food grades of Krytox...... The problem with Krytox is when it gets over 554 degF. Then you can have issues. In a minority of people it can cause skin irritation. But so can any other synthetic or petroleum-based grease. Read the MSDS of any grease you might use for CV joints and I am pretty sure you will get the idea you should not get it on your hands, in your eyes, or ingest it if you can avoid it. Scott |
Banned
Schleprock
Krytox is a DuPont product line. Like Scott said, you have to be specific about which Krytox you're talking about. Not trying to be a dink, saying, "hey man you need to say it's Krytox GPL-215!"
Just saying that nowadays it seems a lot of people have caught on to the Krytox name and think it's just one product like Curil-T, for instance.
Kevin L '86 Carrera "Larry" |
Ah, got it.
I think we can assume that I was not thinking of putting Krytox FG on the Porsche? Or, as spread on my toast..... |
Recreational User
What's the correct term for when a nut and a bolt of different materials cause a chemical reaction that results in them cold welding themselves together? I think that's what he meant.
Schleprock
Sure I know what you're saying. I guess I should have said that some Krytox greases that we'd consider suitable for our purposes are perfectly safe. Others are very dangerous.
Anybody need some aerospace grade Krytox 240? Only costs $2K for a typical sized grease gun cartridge.......... ![]() http://www.mcmaster.com/#krytox-grease/=laljos
Kevin L '86 Carrera "Larry" Last edited by KTL; 02-01-2013 at 02:57 PM.. Reason: added mcmaster link |
Jeezus Kee-rist!!!
I came across (sorry about the highjack) some orange tractor grease that pulls apart about a half foot before it lets go. I could not use any normal degreaser to clean it up. Now I did think "hey maybe I'll try that in my wheel bearings". I use some friction reducer with synthetic oil in the trailer bearings, and for anti-seize I use plain old Permatex copper grease. Works fine so far. I have not tried, nor do I know the application difference between the "silver" and the "copper" anti-seize. Maybe someone can address that? |
