KBOUSTANI's Avatar
which engine and transmition mounts?
i have a euro 76 carrera 3.0 and i am going to be repalcing my transmision and engine mounts.
i used the car for DE and some weekend rides.
i am little confused on which mounts to get.i looked at sports one and solid ones.
please help me decide what to buy.
thanks in advance.
76 carrera 3.0 SSI W/M&K 1RARE76/]89 carrera 4 (964)SOLD
87 targa 3.2,fabspeed cat bypass,sw chip,m&k exhaust(sold)94 carrera 2 cabriolet(sold)00 carrera 996(sold)
95 993,red,meanest looking one(sold)
83 911 sc targa,my first porsche(sold)
Old 02-02-2013, 07:58 AM
Halm's Avatar
When I DE'ed my SC, I had Wevo black transmission and engine mounts. The blacks are harder than OEM sports but softer than Wevo blues, that are softer than solids. All that said, there was a fair amount of NVH into the car.
I have read since then that the better option is OEM type sports on the transmission and stiffer (you choice how stiff) on the engine. This not only helps reduce NVH but allows the tranny and engine to flex in proper unison.
'17 Cayenne
Old 02-02-2013, 08:22 AM
Undocumented User
McLaren-TAG's Avatar
I do a bunch of AX and the occasional DE and I went with the poly graphite inserts sold by our host for the tranny, and with Wevo black for the engine. It's worked out very well, the eye candy factor is nice and it's a good balance although much more noise from the engine and transmission will find its way into the cabin, but that's a good thing.
Old 02-02-2013, 09:10 AM
Banned
Why do you put the less stiff mounts on the transmission, and the stiffer ones on the engine?
Why not the other way around?
And, doesn't the flex in that engine crossbar add something anyway?
Old 02-02-2013, 10:10 AM
Halm's Avatar
Less stiff at transmission transmits less NHV. No idea about the crossbar.
'17 Cayenne
Old 02-02-2013, 11:05 AM
Undocumented User
Some wise folks on this board have suggested the compete opposite. The stiffer in the transmission and the more compliant at the engine. You want the difference in rigidity to allow for some flex and it makes sense to keep the tranny end tighter, I've found with my 915 has helped the shifting. With the wider offset engine mounts allowing for desired flex.
Old 02-02-2013, 11:12 AM
Halm's Avatar
I'll be the first to say that I may / probably have it backwards. That said, I remembered it that way because of a comment about the NVH coming from the transmission mounts. And yes it was a comment from one of the guys I too most respect on the board.
I hope we get this straight be cause I sold the SC and then bought it back after the buyer had changed all 4 mounts back to OEM stock.
'17 Cayenne
Old 02-02-2013, 11:27 AM
AutoBahned
RWebb's Avatar
ok, here is a tidbit I saved on this:
use more rigid mounts at the transmission end only while using softer good (new) Factory mounts at the engine - Grady
- I have no idea why; the moment arm at the engine will be longer
Old 02-02-2013, 01:44 PM
I have wevo blacks in both locations. I like them.
2017 Toyota Tacoma TRD Sport(Hate it)
1965 Chevy Biscayne
Old 02-02-2013, 02:06 PM
Halm's Avatar
Randy, you are correct. Find Grady's entire post here. It is #10.
'17 Cayenne
Old 02-02-2013, 02:29 PM
KBOUSTANI's Avatar
any feedback on the sport mounts
Old 02-03-2013, 08:56 AM
Retired Member
Charlie V's Avatar
I went sports at the engine and polyurathane (stiffer) at the trans. Shifts better, but it does transmit a fair amount of engine vibration into the car. With my firm suspension, etc., this just adds to the raw sports car fell. I like it.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine.
Old 02-03-2013, 10:10 AM
gavinc69's Avatar
Wevo blue's for engine and trans, I think there great..
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, WEVO Shifter, K27 7200 Turbo, OBX Headers, Tial Wastegate, Omex 710 ECU, 3.2 Intake, Full Bay Intercooler.....400HP
Old 02-03-2013, 10:22 AM
Rescuer of old cars
Arne2's Avatar
I'm planning to use sport/cabrio mounts at the transmission and stock OEM for the engine. I figure that should be fine for a street car.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 02-03-2013, 11:03 AM
michael lang's Avatar
I have a set of WEVO mounts for the engine with the blue pillows. For the trans I wasn't sure what to go with so I called Windrush, told them what I use my car for. Based on my car being mostly track but still tagged so I can drive on the street, they suggested I go with black pillows. I'll know if it was the right recommendation when the weather breaks because I can't wait to see how they affect my car.
Mike
'89 CARRERA
#402
Old 02-03-2013, 11:39 PM
Mo money = mo parts
I am doing what Arne is doing, bought them from our host and will put them in this weekend.
Here is another thread that is similar to the one Hal posted where Grady recommends stiffer at the trans, flex at the engine.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 02-04-2013, 06:08 AM
Blackbyrd's Avatar
Running
The new rebel racing engine and transmission mounts
Good stuff for sure
Old 02-04-2013, 10:57 PM
Bad LT
Uncle's Avatar
Sport trans and and billet engine mounts with a RSR engine bar. Very happy with it.
Ex Porsche Cup car with some boost and stuff.
Old 02-05-2013, 02:31 AM
safe's Avatar
Go with solid transmission mounts, it adds tonnes of raw feelings to the car!
Magnus
Old 02-05-2013, 05:45 AM
$ Short's Avatar
Rebel racing trans + motor. Both blue( sport) and would highly recommend.
Old 02-20-2013, 11:29 AM
