Question - Fuel Distributor & Gaskets
I've been working on getting my CIS right, checking pressures, new WUR, fuel lines etc..
In the process, I noticed that the fuel distributor - actually the whole sensor plate assembly, is mounted to the airbox with screws that have springs under them. Mine looked loose and my 1st thought was that theses must not need to be super tight and maybe this whole thing is just sitting on top of the air box but not a critical seal.
After thinking about it, I decided to tighten up the screws and suddenly...my idle surge seems to have gone away.
This tells me that this is a source of vacuum leak and I'm wondering if it's possible to replace gaskets etc... Basically, I'm not sure what's under there and I don't want to start taking apart without knowing what I'm getting into first.
Any advice would be much appreciated.......Vern
Old 02-01-2013, 09:49 AM
Found everything - The PET catalog saves me everytime!
Old 02-01-2013, 12:23 PM
I just noticed you're in Fresno. Have you ever had Tony work on your car? He's a wealth of information.
Old 02-01-2013, 12:34 PM
ROW '78 911 Targa
timmy2's Avatar
Foam gasket under FD and airmeter assembly, o-ring under throttle body and 2 o-rings for CSV.
Make sure your rubber boot from TB to Metering plate is good and tight with no cracks in it.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-01-2013, 01:27 PM
Scott R's Avatar
Tightening up the keyway gasket shouldn't have fixed anything. You can run the engine with airbox cover off and it would simulate the same condition. The large o-ring on the throttle body is a bit more critical however.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-01-2013, 02:17 PM
I used the PET catalog and made a list of every single gasket/o-ring that I have not already replaced. While I'm at it, I'm going to fix a few oil leaks so I looked up all that too.
I'm going to place an order with Pelican tonight when I get home from work - can't do it now.
Old 02-01-2013, 03:51 PM
I'm not sure I know who Tony is - the only Tony I know is Maslowsky in the car club.
Old 02-01-2013, 03:52 PM
You have a vivid imagination........
Vern,
Any air coming through the gap between air box and the air metering unit is simply unfiltered air. It has no effect or relation to your surging idle speed. And won't effect the mixture at all. The gasket between air box and air metering unit is made of light foam material.
Have you pressure tested your system (engine) to locate sources of air leaks? Then have the exhaust gas analyzed with a gas analyzer and set accordingly. Keep us posted.
Tony
Old 02-02-2013, 06:13 PM
Functionista
manbridge 74's Avatar
An interesting aside on the screws with springs underneath. I remember reading somewhere that the screw is tightened and backed off one turn. Not sure why.
Old 02-02-2013, 08:55 PM
