No 5th or reverse
After bolting up my 3.2 motor and rebuilt G50 box, first thing I did was try engaging gears. 1st thru 4th are OK , but I can't hit upon a combination of imput/output shaft positions that engages 5th or reverse. Should I be worried, or is just because there's no fluid movement to turn the 5th/reverse idler gears? Wondering whether to proceed with engine hookups or stop now and pull everything out.
Old 02-03-2013, 09:28 AM
plumb4u2's Avatar
I have no experience with the G50 but on the 915 this is usually an adjustment issue at the coupler
Justin
84 Carrera Targa
98 F-150 4x4
Old 02-03-2013, 09:43 AM
I don't understand. Is there a provision for adjustment at the coupler?
Old 02-03-2013, 10:39 AM
Engineer of profanity
924CarreraGTP's Avatar
It's under the cover on the tunnel just in front of the rear seats. Mark the position of the coupler to the rear shaft before you remove it, so you have a reference point of where you started. You'll probably want to move the coupler a spline or two to the left. Then plug the shaft back in, tighten the coupler and see if you have all of the gears.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 02-03-2013, 10:44 AM
OK. That's on 84-86. It was elimnated on G50 (87-89). Thnx.
Old 02-03-2013, 10:52 AM
Where r you located?
Old 02-03-2013, 11:07 AM
Near u. Lincoln MA
Old 02-03-2013, 05:03 PM
