Rust assessment and advice
Hi
Just had a good poke around under the rear fender of my 1982 sc. Seems pretty solid, but looks like it has spent 30 years in the rain (which it has - UK car).
What do you think guys - an abrasive of some kind and some rust treatment. I guess the patches of bare rust need treating fairly urgently.
Is that supporting panel behingd the door latch replacable?
I will get the sill covers off next weekend. But I used the Porsche jack to lift the car on the jacking points and nothing collapsed - so I reckon thats a good sign!.
Here are some pics of the left hand side:
The right side is better I think:
Interested to hear any comments
Jack
Old 02-03-2013, 12:11 PM
wayner's Avatar
You asked if the panel is replaceable. Yes.
Here are some pics of the process. We drilled out the spot welds.
Also note what we found lurking underneath.
Saving a 73 from the crusher...
SOLD - 914 wide body hot rod
Old 02-03-2013, 01:48 PM
arry911
Hi i would clean the rust areas up and use rust converter then some under seal on them. As you say its a good sign you used the jacking points and its still ok. I use mine all the time just put in the lifting plate i got off Ebay so you can put this in the jacking point and use a trolly jack. I think you should get 101 projects for porsche 911 by Wayne Dempsey if you are going to do work on the car.
Old 02-04-2013, 06:42 AM
