Smoove1010
Smoove1010's Avatar
Time for New Timing Chains?
In the process of getting the chain housings off and need some help evaluating these chains. Engine has 99K miles, 1987 Carrera, doesn't look like it's ever been opened. I'm doing a top-end (87 Drop Top - Drop-n-Top End)
What say you all re: the life-span of these timing chains - time for new ones? I'm not sure what fully-extended tensioners look like, so I've no real good frame of reference...
Thanks in advance for any learned opinions,
GK
Old 02-05-2013, 05:22 AM
i wouldn't worry about it. looks to be plenty of space between the top of the left arm and the housing and both tensioners are about the same, extension-wise.
206 637 4071
Old 02-05-2013, 05:27 AM
Smoove1010
Smoove1010's Avatar
Thanks for the quick reply, that's good to know. BTW - your crowbar picture from an earlier post saved me lots of time getting my cams out...
GK
Old 02-05-2013, 05:38 AM
crowbar?
206 637 4071
Old 02-05-2013, 07:26 AM
Smoove1010
Smoove1010's Avatar
Well, sort-of. Maybe there's a more Porschey name for it...
Camshaft adjustment flange is stuck
Regardless, I took it as empowerment to use a little persuasion on something I thought would fall out once the bolts were removed. That o-ring that seals the flange against the housing has a pretty firm fit, and the gasket that seals the flange to the cam tower probably had a little adhesive on it.
Old 02-05-2013, 08:11 AM
kodioneill's Avatar
Ladies slipper.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-05-2013, 11:41 AM
