ASE Master Tech - 35 yrs
larrym's Avatar
Question 3.2 conversion - what-is-it - can i throw it away
doing a 3.2 ('89 engine) into a 914-6
A. see the pictures and related descriptions below - i want to know what these components are, what they do,
B. are any of these necessary to the engine running normally in a backdated chassis,
C. can i throw 'em away and cap/plug the ports they attach to?
1. vacuum gizmo parts 13-18-22 and associated hoses
2. air valve apparatus parts 28-30-32-36
3. oil tank breathing tubes parts 25-26-28
. ( i will attach the 26 crankcase tube to my oil tank);
do i need the 28 tube which returns to the intake bellows if i am simply venting tank overboard as oem - what happens if i do not have a 'round-trip" positive crankcase suction?
i do not seem to have the 25 tube ????
TIA
Larry_M
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 02-05-2013, 08:00 PM
1- the vacuum accelerator apparatus is not needed. You don't have a brake booster. Plug it off on the intake system
2- you don't need this valve either- plug it on the connections to the intake system
3- You can plug this on the intake system as well. Remove #28 hose completely. The two other breathers connect to the oil tank and neck , as originally done on the 914-6
If you are running an original 914 trans, be careful on hard take offs in 1st. The torque from the 3.2 will break the mainshaft and leave you with no 1st gear. BTDT !
have fun; car will be a rocket
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 02-05-2013, 09:20 PM
Larry thanks for posting the question. I'm just starting to strip parts off an 86 3.2 to install into my sixer. Going from a 2liter 6 to the 3.2 should be fun.
73 914-6, Vintage Spyder,05 997(sold),
04 Anniversary 911 #151(sold)
08 Beck Speedster #317 (sold)
76 911S (sold) 76 911 Targa (cut up & sold)
86 951 (sold)914-6 (sold)
Old 02-06-2013, 03:10 AM
I think on the big hose between the intake boot (by throttle body) and the oil tank you need a restrictor (1/8") hole or you will have a massive air leak and the AFM flapper won't move correctly.
Most conversions I have seen plug it and put a k&n filter on the oil tank,okay for those who like a nice oily engine compartment.
On my 3.6 conversion (AFM) I am using a restrictor that came off a Vanagon, fits hose
Daron
Old 02-06-2013, 08:37 PM
larrym's Avatar
Thumbs up thanks for all the help
thanks to everyone!
- i went by Gary Clark's shop in Auburn, CA & got pretty much same opinions
the oil tank return hose port can be capped off at the MAF elbow - on a carrera, the oil venting system is completely closed to atmosphere , - therefore the "pumping" from blowby in the crankcase is vented back into the intake (for SMOG reasons) - one thing i did note on the 3.2 is that it appears a fair amount of oily vapor had been sucked into that MAF elbow
- we MUST retain a significant volume outlet for venting that pumping blowby - no engine has perfectly ZERO blowby
- in my case i already have the tank externally vented via a race-required catch tank - (just as was done in the original GT's) - mine came that way from the mother country
The air valve gizmo is for purging fuel vapors from the tank canister, i now realize that the 2-port sensor in the throttle body is listed as "thermostatic" - so it closes soon after the engine starts & warms - therefore the air valve is irrelevant to normal running - i'll just cap it
maybe someday i'll fiddle with adding cruise control, so it's nice to have a manifold vacuum source - ( that is assuming i don't sell the car anytime soon)
fwiw - i found a source today for 22mm oil hose - which i need to connect my engine oil hard line outpipe to the 911 oil thermostat-valve that feeds the front cooler - Elephant Racing has it & also has a bunch of those BIG METRIC 24-30mm fittings we need for this task - ( this stuff is really hard to find )
yes, i'm keeping the 901 for now & knew about the torque issue - I do have a good 915, but the expense & hassles of that conversion is beyond my current interest - (i have 3 good 901's, and have talked to several guys who say they'll stand up to 200 hp, if not hot-rodded in 1st, so will cross my fingers!)
and so it goes ....
Larry
Old 02-06-2013, 09:10 PM
Elombard's Avatar
Is there a thread on simplifying these systems on a Carrera hot rod? Seems like I dont need the vacuum and breather systems to be that complex on a non emission car that has had the cruise and many other systems removed.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 02-07-2013, 03:59 AM
larrym's Avatar
Lightbulb
- it makes no difference what body shell the engine is in if it does not require any of the SMOG & vacuum stuff -
I think the guys have provided your answers above
just cap it all off and assure yourself you have not left any places where unwanted additional air can get drawn in behind the MAF flapper to upset the air-fuel ratio intended by the factory
Old 02-07-2013, 10:14 AM
Elombard's Avatar
Larry my car has the stock vacuum assist brakes (its and 84 with an 84 motor). Also the oil breather set up is required in some form. I need to get in there and look at the routing.
Old 02-07-2013, 10:18 AM
larrym's Avatar
Exclamation
aha! - in your 1st post you said you did not need any vacuum systems
you can either vent the oil tank to atmosphere as done in the olden days - see my comments above and Daron's comments - - or keep it vented into the intake as oem - but you can't plug it
what i have seen on several cars is that the prior owner mis-routed the 2 vent hoses by swapping them onto the wrong pipes at the tank - in that case you will lose the air-oil-separation feature built into the tank & you will have an oily mess in the engine comp't
on early 911 cars the vent to atmosphere hose simply went into the air cleaner housing
Old 02-09-2013, 09:26 AM
Elombard's Avatar
Sounds good, I guess I can get rid of one of the vent lines - I wonder if any of the vacuum stuff can be minimized.
Old 02-09-2013, 02:35 PM
