Another cat by-pass question...
I am having a custom cat by-pass made with an O2 sensor port. I should have it soon and plan to get my 911 through VA emissions inspection just before I do the swap. I have heard that my car should pass even with a cat by-pass pipe. Anyone know if this is true or even likely? How meticulous are they in doing a visual to see if there's a cat on there, or do they just look for the O2 sensor wire and assume you're in compliance.
Another issue: I removed my entire exhaust system a few weeks ago when I had my engine out. When reinstalling we used all new bolts, used anti-seize on them and put in new gaskets. Can I reuse them since they've been on there less than a month? Or do I need new ones? Thanks.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Here in Ga it would not pass an emmissions test- they do check for the CC.
I can't see why you would need to replace your bolts... they should be in great shape since they were recently replaced (but what do I know??!!??)
Sean O. Atlanta, Ga. 96 Van Diemen Formula Continental 01 2500HD |
Not Quite Banned
Richard - I have had a cat bypass pipe on every 911 I have owned and have never had a problem passing emissions. Even when I came to Arizona and the visual inspection guy put the mirror under the driver seat area of the car for the 'visual test'...
I now have a Euro-premuffler from Fabspeed on my '88 that I like much better than the straight bypass pipe (it even looks more like a cat). Regards,
Thomas Owen 1972 911T 1972 911S |
You could reuse the bolts and gaskets with no problems.
George My Owners Gallery Page 1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running. 1995 BMW 525I 2001 Highlander- kid mover |
I've passed two emission inspections here in Atlanta with a bypass pipe ( w/ 02 sensor ). Guess it just depends on where you go for the inspection.
HAS ANY ONE TRIED A GUTTED CATALYTIC CONVERTER VERSUS A BYPASS TUBE. IS THERE ANY PERFORMANCE DIFFERENCE.
