oil cooler fan
What size oil cooler fan are you guys using for the front mount oil cooler in the fender? 6.5" pusher? or ? size?
i need to have some additional cooling for my 930 when I get stuck in traffic after coming off of boost it gets pretty warm to about 210* or so. Summer would be much worse.
Thanks,
John
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 02-18-2013, 08:43 PM
cycling has-been
bkreigsr's Avatar
The fan must be a pusher and mounted in front of the cooler. Otherwise, the tire will make contact with a pull fan on tight turns. I mounted a 7.5 SPAL on my 77, but there's room for a 9". I kept it simple and only have a manual on/off switch for when the oil starts to get in the upper ranges.
I think there are several threads here, including proper wiring if you go with a thermostat.
Bill K
Old 02-19-2013, 11:59 AM
cashman's Avatar
I used the Spahl 7.5 as well. It fit perfect. I even used the OEM metal mounts. To make the mounts work you have to drill new holes through them. 7.5 fit perfect for my 89. Larger would have created and issue for me.
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 02-19-2013, 12:04 PM
Go-Kart Mozart
JAR0023's Avatar
I picked up a 7" fan that I plan to get installed before it warms up around here. My early 86 did not originally come with a fan. Here are two threads with some good info in them. -J
Installation of my $15 Oil Cooler Fan.
I plan to use this fan on my Oil Cooler.
Old 02-19-2013, 12:27 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thanks,
John
It depends on the size of your wallet/checkbook.....
I upgraded our '86 3.2 with the factory front oil cooler fan (used)/wiring harness (new),
and the Nasson 210F-on/195F-off sensor.
A BMW sensor will also work.
Also, I wired the fan relay coil to the fuel pump fuse.
The factory oil temp sensor is set to 248F which is too hot.
You may have to add a sensor bung on your oil cooler.
pm for additional details.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 02-19-2013, 12:52 PM
I think Elephant Racing has a cooling fan it may be worth a look.
Old 02-19-2013, 01:20 PM
ELEPHANT RACING Oil Cooler Fans
Old 02-19-2013, 01:22 PM
Hmmm. I was about the throw the spal fan idea out when I saw the $15 fan, but then the ER fan looks nice at 4.5amps! with 400cfm. Glad I posted this. More options than I thought there were.
Old 02-19-2013, 01:27 PM
French Import
zippy_gg's Avatar
Good luck,
Gerry
Gerry, is this the BMW type that will also work?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-19-2013, 01:40 PM
Sensor.
Yes, and by the way, that pic is from one of my earlier posts.
The Nasson sensor can be custom ordered.
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-19-2013, 01:43 PM
Barrpete's Avatar
I used the aftermarket kit from Elephant Racing. 8" pusher fan, 2.25 in thick. The install kit includes the relay, fuse, wiring and an adjustable controller so you can set the fan to come at whatever temp you want between 170 & 210. Not quite plug and play because I had to fab an upper cooler bracket and move the horns a bit, but you pretty much need to do that regardless of which fan you use.
I put this in about 5 or so years ago and it still works fine. Makes a huge difference on oil temps in summer when I'm running the AC.
'86
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 02-19-2013, 02:29 PM
cashman's Avatar
I don't know the quality of the $15 fan. It may be great. My suggestion is that you put in a good one. You won't want to do this again. I chose the Spal based on its good reputation.
Old 02-19-2013, 03:43 PM
French Import
zippy_gg's Avatar
Gerry
Yes Gerry, this is the picture you e-mailed me a while back.
I see that the original "bad guy" only has one connector while the BMW has 2. How do you correctly connect the BMW switch? Thanks!
Gilles & Kathy
Old 02-19-2013, 03:53 PM
Member 911 Anonymous
DRACO A5OG's Avatar
you can also pick up an adjustable thermal switch with relay and wiring at pepboys $40.
I picked one up for my rear lid fan, ready to install.
'85 Carrera Targa
PCA/POC
Old 02-19-2013, 09:50 PM
Switch.
The factory harness has one connection to the switch, and another connection which grounds to the oil cooler.
When using the BMW switch, one wire (hot),goes to the switch, and the other (ground), grounds to the oil cooler between the base of the switch, and the oil cooler.
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-20-2013, 08:11 AM
French Import
zippy_gg's Avatar
Gerry
Thank you Sir!
Gilles & Kathy
Old 02-20-2013, 12:08 PM
