Today while pulling out of my garage, I turned on my lights,drove away, and noticed that my speedometer wasn't working. However,when I turned my headlight off, the speedometer started working again. Lights off, not working. Lights off speedometer works. What gives? I recently took out the speedo and replaced a gear inside. Could it be that I didn't connect the wires properly?
Thanks for your help! |
When my alternator went out, the car drove fine for a while. Then all the electrics inside started acting up.
Every cloud has a silver lining (except for the mushroom shaped ones, which have a lining of Iridium and Strontium 90) 08 Cayman, 88 911 Targa, 93 MR2 Turbo, 2012 Jeep JK |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
![]() ^^^^^ Prevents IC damage. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Banned
kdubb - to check the alternator/voltage regulator output, measure charging voltage at the battery terminals with a multimeter (with and without lights on) . . . you should see 13-14 volts at 2K RPM (sometimes might be a bit less when the engine is hot and all of the accessories are on).
Is very busy
Sometimes my speedometer doesn't work either, but after driving for a few miles it starts working again, but it only seems to happen during cold weather. Since it's spring and warm, it doesn't happen, but that's just my speedometer.
Jason 1987 930 Slantnose Cabriolet, 545 hp, Guards Red- Weekend cruiser 1986 944 Turbo (951), 350+hp, Guards Red- Track car 2005 Toyota Tundra SR5 Double Cab 4x4, stock 282 hp, Silver- Daily driver |
Member 911 Anonymous
Do what Dr Gerry wrote and also check the ground is nice and clean/solid.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
1st step is always check output with a multi-meter.
poof! gone |
El Duderino
Don't you avoid this problem altogether if you simply disconnect the negative terminal at the battery before messing with any of these connections, and then reconnecting when you're done?
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Your speedometer case/circuit is not properly ground. Instrument light backflow is providing the needed ground.
Dash instrumentation bulb power off, low bulb filament resistance provides a ground path "backward" through the filament to other bulbs that do have ground connection. |
Check to make sure those two brown wires are firmly conected. The Bentley says one of those wires goes to G116, trunk floor plate left (below fuel filler tube).
Is this car in the 84-89 trange?
Rick 88 Cab |
I don't see what attaching power last really does since theoretically that is an open circuit. When connecting something up hot it is a good practice to connect ground followed by signals and then power but that is not what is done here and no one mentions the ground connection first.
Rick 88 Cab |
El Duderino
Rick,
My point was that if there is a risk of damaging a component because of connecting things back in the wrong order, then the safe thing to do would be to disconnect the battery. Seems to me that it would be really easy to create a short to ground with all those wires dangling around. And at least on some cars the instrument cluster is unfused. Really easy to let all the magic smoke out and it's easily avoided.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. Last edited by tirwin; 04-14-2014 at 10:02 AM.. |
Thanks to all for replying
I will check the connections as well as the order of reconnecting the wires and reply to this thread.
Also, thanks for the heads-up on disconnecting the battery before any electrical work is done. Sounds simple, but I did not think of that. Kevin |
