The Dilavar studs are non-magnetic. However, the barrel nuts on the end of the stud are quite magnetic, and your pick-up tool is going to contact the nut before the stud.
Quantum Mechanic
When I check them using my Snap On torque wrench, click type, they "ring" a little bit when the wrench clicks indicating proper torque (23-24 ft/lb)
Ping ! If they twist and do not hold torque, they are probably bad :-)
Mark Petry Bainbridge Island, WA 81 SC |
5String
Is your car making the telltale "playing-card-in-bicycle-spokes" noise? If it is not, you might be OK. My car, an '82, was making that noise. The resulting "while-you're-in-there" tab was far north of the $3,000 you mention. Good luck with this. It's way to easy to spend lots of money on these things.
5String Tell not a soul that you have seen me; breathe not a word of what I say.... The Northwest Files |
btw UK here, so I was thinking £ - even so probably more.... Last edited by mr911er; 02-11-2013 at 11:17 PM.. Reason: bad spelling |
Honey Badger
Thanks! |
When I went to try my first valve adjustment, I discovered 7!!! broken studs. Previously did not hear bicycle spoke sound and car ran— not as well as after the rebuild by Dan Jacobs though.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
anyone else find 12 broken studs?
rs6er
7 broken dilivar studs arent too bad. I just found all 12 of the dilivar studs on my 80 sc were broken. Is this rare? |
wow all 12 ? did you have performance issues or just get the car ? I cant belive you could drive that thing without noticing having 12 broken studs. i would be worried about corrosive exhaust gasses escaping betwen the cylinder and head and doing serious damage ..
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
