Ryan
Teflon tape oil fittings?
I'm replacing my cam chain oil lines and don't want leaks. Should I Teflon tape the fittings?
Rescuer of old cars
Done properly, there should be no need. But if you decide to do so, make certain you use the special tape for fuel/oil/natural gas, etc. That tape is typically yellow in color.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Mo money = mo parts
I wouldn't use teflon tape., but I often smear a little Curil-T on threads and crush washers. It's an excellent product and really does help seal your motor. Our host sells it.
However, never forget the old adage "if there is oil in it, there is oil on it". ![]() ![]() Here's a product sheet.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Use it by all means, but make sure no loose bits can get dislodged an get into your oil system. No need for the yellow gas specific tape. I used to manufacture the stuff and trust all that makes it different to the regular white tape is that it is certified to have an oil content below a certain threshold, which is in any case irrelevant to your application.
'70 911T (AKA Bottomless Pit) - Undergoing restoration '13 Audi A4 1.8T - Surprisingly fun means of getting to work |
Senior Advisor
here is a good rule of thumb (s) if the threads are the sealing device, (like pipe thread fittings) tape or compound is ok, if the threads are the mechanical clamping force (like in AN, flare, or compression fittings, O-ring/gasket) than no sealing compound is needed.
08 Cayenne Turbo Last edited by James Brown; 02-14-2013 at 11:39 AM.. |
non-whiner
The seal is not at the threads, it is at the nipple. No sealant is required, however I use a little thread sealer (not tape, that is for home plumbing) on the threads to ensure any weeping is stopped plus it makes it easier to disassemble if required.
Never use teflon tape or silicone rubber sealants; pieces of tape or little beads of rubber can break free and clog critical oil passageways. I also use a light coating of Curil-T when required. Jim
Diss Member
No, NO, NO!!!
Do not use teflon tape. It only increases the chance of a sealing issue (or much worse). If it doesn't seal correctly when torqued anywhere near correctly then you have an issue the requires parts replacement. It always amazes me when I see AN fittings with taped threads. If the fluid reached that far then the connection has already failed. It basically is an overt sign that someone has worked on it that doesn't know what they are doing. James has got it exactly right: Quote:
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
I used teflon tape carefully at the thermostat in the wheel well where the steel fittings attach to the aluminum thermostat (dissimilar metals=corrosion). I'm hoping that next time I have to remove the lines that it won't be with a dremel tool!
1978 SC coupe #1834 Last edited by Brown747; 02-14-2013 at 03:15 PM.. |
Schleprock
I'll reinforce what everyone else said- no need for teflon tape on the cam lines. The banjo end seals just fine with barely any torque applied. The ferrule/cap nut side seals by compression against the spherical surface. No need for any kind of sealant in or around the connections. Hook 'em up dry and you'll be fine.
Where teflon tape really shines (NOT) is on fuel system kludges. The tape turns to goop and makes a mess. The tape has no business being used on a car. Actual teflon hoses are fuel resistant. But the "teflon" tape is not. The Curil-T stuff is becoming a popular item in the Porsche 911 community. Putting it on the crank seals as shown in that picture is like begging for the seal to come back out. The rubber seal is ribbed on the surface to help it "bite" into the bore and stay in place. The Curil T does not harden and acts as a "lubricant" on the rubber seal surface, somewhat defeating the purpose of the ribs. That said, some lubricant is often helpful to get them installed cleanly. Water or some spit (anything that will dry up eventually, but not lubricate) works best IMO to let the seal stay put! A swab of oil around the seal lips is always a good idea to let the lips slide along as you press the seal into place.
Kevin L '86 Carrera "Larry" |
Ryan
I'll stay away from the tape. Thanks guys
Yep....Keep it for leaks in your bathroom.
No place for it in a car.
1978 911SC |
