Unhappy 87 DME recommendation
My 87 Coupe has been parked for 1 month with a bad DME. At this point I would appreciated a recommendation from someone with more Porsche experience than I have. Here is the background.
I purchased an 87-911 carrera 1 year ago. I have upgraded it quite a bit over the winter, inspired greatly by this Forum. Since taking it out I have had an intermittent stall problem. I borrowed a friend`s DME and isolated the problem to the DME. I have read on this forum how to open the box and re-solder some contacts. I have done this successfully. The DME worked for a while. Now it does not anymore.
My Porsche is garged until I find a solution. Here are the options as I see them:
1) purchase a used DME. (approx $400, scarce, no warranty, 15 years old)
2) purchase a rebuilt from a Porsche dealer ($700+$300 core as my unit has been openened frequently, 2 year warranty, still a 15 year old unit).
3) purchase a new Porsche DME ($1,500, 2 year warranty, brand new unit)
I am tempted to purchase a new one. I find that $1,500 is outrageous but feel it is the only solution that will solve this problem permanently. Otherwise I will continue to have the fear of having the car towed every time I take the car out.
Are there any other solutions? I do not believe our host carreis them.
Does Bosch sell the aftermarket DME? Is it cheaper than a dealership unit? Where from?
I appreciate any feedback on this one.
Richard
Old 10-01-2003, 10:03 AM
If it were me I'd try and fix the DME unit. Mine took two tries since I missed a broken solder the first time. I would be very reluctant to pay a small fortune for a new DME. I believe it was Jim Sims (very knowledgable poster) who said these things are pretty robust, other than the broken solder issue. There's something to be said for the peace of mind with a new one though I guess.
Later,
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 10-01-2003, 10:09 AM
Try here: http://www.programainc.com/
They can repair or rebuild. Worth a call to explore options.
There are also a few threads on this subject.
Warren & Ron, may you rest in Peace.
Old 10-01-2003, 10:11 AM
IROC's Avatar
FWIW, I think I saw that Vertex sells new ones for less than $1000 if you decide to go that route.
Fixing the one you have seems like the best option, though. Evidently the solder joints at the big ignition transistor are the weak spot. The rest of it seems pretty robust.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 10-01-2003, 10:13 AM
Whichever route you take let us know how you make out.
BTW, do you have the stock chip in there?
Old 10-01-2003, 10:16 AM
Sports Purpose 911 Driver
mjshira's Avatar
contact www.tremotorsports.com I know that you can send your DME to them and they can get it gone over and back to you having been tested and ready to run.
James
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 10-01-2003, 10:20 AM
I called Gabriel of Programa to get a sense of the R&R service they provide. Here's what I've learned:
- Apparently 911 cores, in good shape, are hard to come by. Additionally, volume is very low.
- A rebuild service is available for repairable boxes. Water damaged units can sometimes be rebuilt but chances are lower (much).
- All work is done on a case-by-case basis as there are many variations, even within model years.
- When rebuilding the unit is not merely repaired. The unit is completely tested using multi/many step process...using a stock (known baseline) chip.
- If there are known weak spots or upgrades that apply to your unit then they are addressed during the rebuild.
- They will match Vertex prices.
- Three year guarantee.
- It would REALLY help to have the Porsche AND Bosch part number when contacting them.
- They also rebuild ingnition amplifiers. (?not sure i know what that is?)
BTW, I have no financial interest in this company. I'm merely providing facts to make an educated decision.
Old 10-01-2003, 11:06 AM
Gents,
Thank you for the information, the leads and the moral support you are all providing. My action plan is to contact Programa and proceed from there. I will post my final resolution.
Thanks again Rickm Mjshira 88911coupe and iroc.
Old 10-01-2003, 02:03 PM
Platinum Member
dad911's Avatar
Option 4: Buy my DME w/autothority Mass flow sender & K&N Filter for $900 plus shipping.
Old 10-01-2003, 02:12 PM
Lorenfb's Avatar
Did you do a search with Google or Yahoo using "DME Control Unit"
or "Porsche Motronic Unit"? There are many more sources available
for the Porsche DME unit than have been mentioned.
You might call Tom Gould at Pelican Parts. They may have some
sources that they provide for rebuilt units.
Good Luck
Loren
'88 3.2
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 10-01-2003, 07:47 PM
check out dcautomotive.com and see if they have sold the one from the 87 targa they are parting out. they seem to charge 350-500 for the ones on their web site.
regards
Haz
1987 Venetian Blue Targa, 24,000 miles, runs like "buttah"
Old 10-01-2003, 08:05 PM
Eric Coffey's Avatar
Buy a used one! Even at $400 a pop (from a reputable used parts/salvage co, ebay, etc.), you could have two "spares" for the price of one new unit.
Old 10-02-2003, 10:26 PM
