964 Compression test results
Just got the results from a PPI performed on a 1990 Carrera 4 with approximately 60k miles that I am thinking of purchasing.
While the local dealer said their leak down equipment was not operating they did perform a compression test with the following results. Cyl #1 - 200psi Cyl #2 - 205psi Cyl #3 - 210psi Cyl #4 - 205psi Cyl #5 - 205psi Cyl #6 - 210psi Other than that the only other item noted was the lower valve cover gaskets have minor oil seepage. Thoughts? |
Those numbers look good. No 1 is slightly low but not a problem, it wouldn't keep me from buying the car if everything else checks out.
Kurt |
200 psi, within 5% of each other, is not low.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
JMHO,.. but you REALLY need a leakdown test. Those numbers look OK, however oil viscosity and temperature affect the readings.
Leakdown tests OTOH, give you definitive information about valve & ring sealing.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Red Line Service
Do yourself a favor. Go to a local INDEPENDENT shop. If you need a recommendation call your PCA zone rep for your area, Porsche Club of America - Home, and ask him for a good INDEPENDENT. Definitely have a leak down test done. And anyone that says a 1990 964 has no problems except for damp lower VC gaskets either didn't look or isn't telling you everything. Test his knowledge and ask him if the car had the cylinder update, a qualified mechanic can tell visually from under the motor.
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
Thanks Marc and the rest of you for your input.
To make a long story short I made an appointment at a local independent shop that was recommended by the local PCA for a leak down. It was what I should have done originally, but I went against my instincts. It does suck to have wasted the money at the dealership, and essentially pay twice now for a PPI, but in the long run it is the smart move. |
Red Line Service
Good luck with it. I love my 93 RS America 964, great era of 911.
