930 rear caliper piston orientation?
Hello, I'm putting the 930 brakes on my 3.2 Carrera, and I'm confused on the piston orientation. Searches have shown the piston orientation on the rear 930 caliper to have the high side of the step on the top. Since the caliper mounts on the front of the trailing arm for the 3.2 conversion, instead of the rear, shouldn't the step be on the bottom, same as the front calipers?
Mike
1986 3.2 to 3.4 conversion
Old 02-18-2013, 02:06 PM
Bill Verburg's Avatar
Mike
The edges of the shoulder are to be parallel to the pad guides at the edges of the calipers, the setback portion sees the rotor first when the car is going forward.
If you follow the above it doesn't matter which end of the car they are mounted on or whether in the leading or trailing position.
Bill Verburg
Old 02-18-2013, 03:21 PM
Bill, thanks for the response. To be clear, by 'setback portion', you mean the non-rasied side?
Mike
Old 02-18-2013, 05:01 PM
proffighter's Avatar
Maybe this helps to clarify
Roland
930 Turbo '81 Too many modifications to list
Old 02-18-2013, 11:45 PM
Mike
yes, on side is depressed or setback the other is raised or proud or elevated
the depressed side greets the new edge of the rotor as it rotates. The proud side says goodbye
Bill Verburg
Old 02-19-2013, 03:49 AM
Excellent Bill. Thanks.
Old 02-19-2013, 06:54 AM
proffighter, thanks for the picture, thta helps with a lot of things.
Mike
Old 02-19-2013, 04:21 PM
