Replacing Oil Fed Tensioner Lines
My 2.4 in my 1973.5T was fitted with oil fed tensioner's about 10 years ago. Those rubber hose sections in the feed lines just above and outside of the chain cover are slowly weeping oil indicating they are spent! Getting the left and right replacements are no problem and it appears fairly simple to remove and replace.
The big question is: Do I have to drain my oil to get this done?
If anyone can provide first hand experience in performing this replacement please chime in.
Bob
73.5T
Old 02-19-2013, 02:25 PM
schumicat's Avatar
no. it isn't a hard job.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 02-19-2013, 02:59 PM
French Import
zippy_gg's Avatar
As my engine is out of the car with no oil in it I cannot comment on the need to drain or not. It is an easy job. Be sure to replace the washers on the banjo connectors.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-19-2013, 03:59 PM
