Rear gearbox boot
I need to order a gearbox boot for my 911sc as I ripped mine when removing the engine and transmission. Looking at Pelican Parts, I think it's
911-424-294-00-M260 but not sure and can't fine parts diagram with the boot. It's the rubber boot that is fitted where the gearbox shaft goes back into the car. Thanks |
Senior Advisor
yes that is correct, do you have the PET parts break down? it's in group 7, item 67 it's a free PDF download of all the parts good to have. Click on the "can't find it?" box and select the correct car then search away
08 Cayenne Turbo |
Great, thanks. just ordered and downloaded the pdf.
And you can replace it when the engine is in the car.... I just did yesterday... you have to work it on to the metal surrounding the shift rod... but doable with a flashlight and patience..
J 911 SC - 1980 911 S - 1977 |
