Follow me
seymore's Avatar
Question Should this be open?
Hey guys, this is the original posted about oil in my heat exchangers.
Oil in the heat exchangers?
I am getting exhaust in the cab with me. Through the side vents.
I was changing my trans oil today and noticed this. It on the SSi and when I stick my finger in it there is oil in it. Could this be the cause of my problem and if so what should I do? Plug it?
1982 911SC
Old 02-21-2013, 11:31 AM
Follow me
seymore's Avatar
And as you can see there is oil all over the SSI from somewhere.
1982 911SC
Old 02-21-2013, 11:33 AM
kodioneill's Avatar
That pipe is made for MFI injection engines to preheat the pump enrichment through a small hose attached to the MFI pump. if you have oil in the exchanger it's coming from somewhere else.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-21-2013, 11:52 AM
Follow me
seymore's Avatar
Would it be ok to plug the hole?
1982 911SC
Old 02-21-2013, 12:19 PM
scarceller's Avatar
Sure, but most likely this is not the cause.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 02-21-2013, 12:26 PM
scarceller's Avatar
Do you have any other oil leaks? Any oil leaks in front of the main engine fan? You need to figure out how oil is getting into the heat exchanger? Look at the inlet side of the exchanger is that end oily?
Sal
1964 356SC (SOLD)
Old 02-21-2013, 12:30 PM
tobluforu's Avatar
That hole would be the cause of some of the smell getting into the cabin so plug it. Looks like oil is coming out of the valve cover studs and somewhere else up high.
Old 02-21-2013, 12:44 PM
Taking it apart is easy
Jerome74911S's Avatar
I found oil on my left SSI that looks just like yours. It turned out to come from a leaking camshaft/tensioner oil line. The oil ran all the way down the engine tin, then leaked out as it appears in your photo. Anything is possible.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 02-21-2013, 12:55 PM
scarceller's Avatar
Keep in mind that with engine running you always have air flow through the heat exchanger, as long as you have everything in place in the engine bay. This means that the inside of the exchanger has positive air pressure and the hole you are questioning would not be able to have air flowing into it, it would have air flowing out of it.
But if you don't have the rear engine bay heater fan in place and all it's duct work then things would change. Do you have the rear heater fan in the engine bay?
Sal
1964 356SC (SOLD)
Old 02-21-2013, 01:06 PM
Follow me
seymore's Avatar
Yes to the fan. I just had a valve job last year with new seals and nuts. The ssi were put on as well. I know these cars are notorious for leaking. But when I look under the car it look like its leaking from everywhere. I need to take it to the car was and spray it down then keep an eye on where its leaking from.
1982 911SC
Old 02-21-2013, 01:40 PM
scarceller's Avatar
Yes, clean it up then always look for the highest oil wet spot. Looking at the bottom won't help find the issue.
Inspect the inside of the rear heat blower in the engine bay, does it show oil inside? Look at all the heat ducts to see if you have oil in those. Also look behind the main engine fan, inside the engine shroud, many times oil is blown by the huge engine fan all over the inside of the shroud.
Sal
1964 356SC (SOLD)
Old 02-21-2013, 01:44 PM
Follow me
seymore's Avatar
Thanks for the help. I will look around the fans and give it a wash
1982 911SC
Old 02-21-2013, 01:49 PM
