Porsche script on an SC?
My guards red SC is getting a full re-spray. I really like the Porsche script & stripes on numerous cars I've seen, but haven't seen it on a red SC.
To work, it would likely need the standard rubber side-strip left off, which would probably meen the sill panels left off too. Hmm..... Does anyone have a pic of a red SC with script? |
I believe the script isn't commonly put on SCs, but I could be wrong.
Regardless, I've always felt that it is your car, so you should do what you think makes it best for you. If you have a good clean side shot of the car, someone may be able to do a quick photoshop for you so you can see what it would look like.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
Thanks for contributing O, but it's looking like nobody thinks/thought it was a good idea & haven't done it.
The rubber strip covering the sill cover's the issue. If the side was smooth paint, I'd go for it. |
What color are your wheels?
I've always felt that the script works best in concert with the wheels. On my black car with RSR style wheel finish, I can go with silver for instance. On this red car (not mine), with RSR style wheel finish, black picks up the other color on the wheels. If you had gold wheels on a red car, I'd go with a gold stripe. A secondary consideration is colors that compliment the body. Black on red, white on red, gold on red, yellow on black etc. (but someone probably figured that out the wheel color was selected). ![]()
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html Last edited by wayner; 02-21-2013 at 11:59 AM.. |
86FlatSix
I just did this 2 days ago. I chose the Porsche 3-line script since most I see are Carrera scripts and I wanted to try a different rendition.
![]() ![]() ![]() IMHO, the black script blended well with the rockers and satin black Fuchs. As they say different strokes for different folks.
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
JQ, that looks really great. I think a good script lends more flow to the visual lines of the car.
86FlatSix
Hi, I don't know if its psychological but with the script it looked sportier/wider as what you've mentioned "lends more flow to the visual lines of the car". I said to myself, I would think most would not like it but I want it a little bit different.
Thanks guys, especially JQ911, good on ya!
It looks a lot better than I thought it would. More optimistic now. Wayner.....good point, my car is same as JQ's. I haven't seen it yet (it's 350 miles from me), but the wheels are at least presentable apparently. |
JQ, before you decided what to fit, did you do any research to see if there were different fonts or letter-shaping available?
86FlatSix
I ordered mine at No Bad Days Graphics c/o Joe Bob and he wanted to know my specs. I just told him that I wanted the script to fit within the doors and was told that the fonts might be a little smaller than the usual. Hope this helps!
Coincidently, I just saw this on the "hot rod impact bumper 911s" thread...interesting treatment of the script..
Doug Currently Between Porsches PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944 |
see joebob .. he is the man .. he does custom work also ....
plus if you don't like them after a while take them off and no harm no foul ... or you can order another color and you have a whole new look ..... |
that last one looks pretty sharp imo
Weseeeee911
+1 on the last car looking sharp!
Al 80SC 95-present |
Dan '86 Carrera coupe |
He also has mobil pegasus and skeleton thingies. Pretty trippy.
Ruby911
I did this on my old Carrera a few years ago. I too wanted something different than the Carrea script. I tried removing the rocker trim molding before I added the decal because I thought it might look too busy. But, the paint under the rocker trim looked like hell, so i put it back on. My car was a dark red and I wanted subtle, so I went with black script. I loved the look - go for it.
- Farrell ![]()
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
The white cab is a backdated SC.
