Question Smoke testing
Has anyone ever smoke tested for vacuum leaks.
Seems like it would be easier and less messy than spraying fluids or using propane.
Smoke testing was mentioned in another thread on chasing vacuum leaks.
I saw a youtube video that also exposed gasket leaks on a valve cover of a V8. All be it above the fluid line ,but a leak just the same to quote the author. I am going to search the forum just thought I would ask anyway.
Thanks for any comments
Old 02-22-2013, 11:37 AM
LJ851's Avatar
One of my other cars is an '89 BMW 325 (E30 Chassis).
The E30 community uses the smoke test a lot as they are prone to intake leaks. It is a very effective tool to pinpoint intake leaks, even very small ones.
Old 02-22-2013, 11:45 AM
sjf911's Avatar
If you have a smoke generator it's pretty good, I just pressurized my system at low pressure with a regulator off my shop compressor and sprayed soapy water everywhere. That worked really well without having to source smoke.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 02-22-2013, 11:50 AM
Project Addicted
There is a thread here on using a shop vacuum cleaner, run in reverse to pressurize the engine enough to spray soapy water to discover leaks.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 02-22-2013, 12:31 PM
Senior Advisor
James Brown's Avatar
only problem is smoke/bubbles will come out of everything!!! maybe you just don't want to find out
08 Cayenne Turbo
Old 02-22-2013, 02:12 PM
Bill Verburg's Avatar
A good shop will have a machine that does this, they are expensive so not likely to be found in a private shop but are the nuts for finding vacuum leaks
Bill Verburg
Old 02-22-2013, 02:14 PM
Basic concept is pretty simple - these guys built one with a paint tin and a compressor DIY How-to: build a vacuum leak detection machine - Pennock's Fiero Forum
They recommend burlap or cheap stale cigars Guess you could burn something else, you might need to pay attention to what you're getting on any sensors...
'77 S with '78 930 power and a few other things.
Old 02-22-2013, 04:44 PM
Project Addicted
Found the shop vac thread
Finding CIS vacuum leaks - the vacuum cleaner pressure test
Jon
1966 912
1986 944
Old 02-22-2013, 05:36 PM
howard freeman's Avatar
Smoke machine is the cats meow for finding unmetered air leaks. In the old days Porsche had us pressurizing the intake with shop air & using soapy H2O. I gave that up especially with the modern BMW's. You will never find the leak without a smoke machine.
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 02-22-2013, 06:21 PM
