matt gineo's Avatar
Major steering issues!
I just got my 76 911 back from the shop after having the front end lowered and the steering is a mess! I had the front end lowered approx. 1 inch to 25 3/4". Before I brought it in to be lowered the steering, handling etc. were perfect. After getting it back from the shop yesterday I'm having the following problems with the steering.
1. it's much harder to turn the wheel.
2. Lot's of play in the wheel.
3. The steering wheel does not come back to center after making a turn.
Any ideas as to what may have happened?
Matt
1976 911 Targa 2.7 CIS
Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior
1963 356 SC- crashed
1962 356 C- sold
1965- 912- sold- fun but too slow
Old 02-23-2013, 10:46 AM
tobluforu's Avatar
Did they just lower it and not align it?
Old 02-23-2013, 11:17 AM
matt gineo's Avatar
It was not aligned, but the issues I'm having seem way more of a problem than an alignment problem?
1962 356 C- sold
Old 02-23-2013, 11:29 AM
bgyglfr's Avatar
Lowering it will cause the front wheels to lean in significantly. I would think that lowering it a whole inch could very well cause those problems if it wasn't aligned. Even aligned the steering might be more jumpy if that makes any sense. Did you have a bump steer kit installed? It would help and you should do it before the alignment. Even the cheap ones help some.
Kirk
70T 2.7RS spec.
68L coupe
Old 02-23-2013, 11:37 AM
matt gineo's Avatar
I thought you only had to install a bump steer kit if you went under the standard european ride height and I'm not having any issues with the steering when I go over a bump.
1962 356 C- sold
Old 02-23-2013, 12:19 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Read:
Corner balance!
Lowering the front end without a corner balance will give you the same result as I got from my PO's son's shadetree mechanic experiment.
These cars are simple, but with the gamut of adjustment possibilities, lots of wrong, is just a wrench turn away.
I have gained a lot of respect for the good Dr.Porsche.
Good luck
Eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 02-23-2013, 03:22 PM
cnielsen's Avatar
Check the steering rack. Almost sounds like the retaining clip on the end if the rack snapped loose and the shaft now has all kinds of play on the one side.
Otherwise...proceed with a proper alignment.
Old 02-23-2013, 03:29 PM
To troubleshoot, you can turn the front height adjusters up two full turns each, and test drive. If the problem goes away, it's an alignment issue. If it doesn't, something else has gone wrong. The reason I say two full turns is that it will be easy / quick to put back exactly how it was - just note the way the wrench handle faces.
Matt - 84 Carrera
Old 02-24-2013, 02:11 PM
if your tie rods arnt close to level you should have a bump steer kit.
Old 02-24-2013, 02:35 PM
Dueller's Avatar
Matt
When you lowered the front the toe changed (hence the steeing not coming back to center and loose feeling), the caster changed (hence the hard steering and not coming back to center) and the camber changed (play in the wheel).
Makes sense to me. I'll bet one side had to be lowered more than the other to make it even ride heright.
Get it properly aligned and you will be fine.
I'd recommend you take it to another shop because the yahoos who just lowered it and nothing else obviously have not a clue as to what they're doing. A monkey with a 10mm can lower it with the turn of one adjustmet bolt on each side. In about 2 minutes. Without a lift or flashlight. Hope you didn't pay a lot to this shop for this "service."
Of course I could be wrong and your flux capacitor reservoir could have sprung a leak.
Jim
1987 Carrera
2002 BMW 525ti
1997 Buell Cyclone cafe project
1998 Buell S1W: "Angriest motorcycle I've ever ridden."
Old 02-24-2013, 04:05 PM
Northern Motorhead
wildcat077's Avatar
What Dueller says ...
By lowering the car almost one inch they added quite a bit of toe out to your front end which will make the car very squirrelly and want to change lanes on it's own ...
Go to a real aligment shop that knows Porsches and get it set up properly !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 02-24-2013, 05:01 PM
pete3799's Avatar
I beg to differ......the monkey would need an 11mm wrench
Pete
79 911SC RoW
Old 02-24-2013, 07:15 PM
Dueller's Avatar
I stand corrected. LOL
My monkey was pulling the valve covers today.
911's....when in doubt its usually an 11 or 13mm!
Jim
1987 Carrera
2002 BMW 525ti
Old 02-24-2013, 07:24 PM
