tig tig is offline
Decode it.
tig's Avatar
Caliper rebuild?
Today I finally started the project to install turbo tie-rods and do my brakes.
My car ('88 Coupe) has only 37K miles on it. The brake pads have been replaced once since new, but the rotors are still original and at about 22.5mm. Since I'm pulling the rotors hubs off to install the turbo tie-rods, I figure I might as well replace all the rotors now too.
So far I've only pulled apart the left side. In doing so I noticed the rubber seal on the rear caliper is worn/torn.
I assume this is Bad and a caliper rebuild is required to address this?
How hard is it to rebuild calipers? Should I get a pro to do it?
'88 Porsche 911 Coupe - Venetian Blau ║ '78 Mustard FJ40 "Uglina" ║ '87 BMW 529i "Maytag" ║ '87 BMW 535is "Vlad" ║ '85 BMW 528i S54 "Minerva"
Old 03-24-2013, 07:17 PM
cashman's Avatar
If your capable of doing the rotors and tie rods you are capable of rebuilding the calipers. The rear rubber boots are hard to put on. They harve about 10 small pins that hold it in place. There are several methods posted on the forum about creating press tools using baby jars or PVC pipe etc. My method: bend in every third pin, no tools needed and they hold on fine. Very easy method.
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 03-24-2013, 07:28 PM
jibmaster1's Avatar
Easy! Did all four corners on my 85' last summer and it was easy.
Do some searching on this site. Super helpful. Rebuild kits are cheap cheap! Good luck.
Send a message via AIM to tmblackflag Send a message via Yahoo to tmblackflag
I tried last year to rebuild my old calipers. It wasn't too difficult until I had to seat the new metal rings and dust caps. I didn't have the patience to do this and just bought 4 rebuilt calipers and slapped them on. I will do that again if the calipers ever need replaced.
1986 3.2 Meteor Metallic Grey
Old 03-24-2013, 07:30 PM
Senior Advisor
James Brown's Avatar
if you keep all the discussions in the same thread, it will be easer to reply to questions
08 Cayenne Turbo
Old 03-24-2013, 08:11 PM
winter
Winter's Avatar
You can do your brake rebuild easily. I was Intimidated but this forum was amazing in regards to help and assistance. Do a search here, ask questions and go for it!
Old 03-24-2013, 08:16 PM
Air Cooled
Craig_D's Avatar
It's fairly straight forward. I just did mine during my suspension rebuild thread. If you'd like to see just how I did it, HERE'S THE LINK.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 03-24-2013, 09:58 PM
